Hi.
1. Your ATV model (2 or 3) and firmware version (found under the ATV settings > general > about > Apple TV software)
- Apple TV3 5.2.1 (considering updating firmware)
2. The DNS server set on the ATV (found under the ATV settings > general > network > DNS):
- 10.0.0.10
3. The device and operating system (including version number) that PlexConnect is installed on:
- Windows Server Enterprise 2008 R2
4. The local IP address of the device that PlexConnect is installed on
- 10.0.0.10
5. The device and operating system (including version number) that the Plex media server (PMS) is installed on:
6. The Plex media server (PMS) version number you are running (**do not put 'latest'**)
- 0.9.7.28
7. The local IP address of the device that the Plex media server (PMS) is installed on
- 10.0.0.10
8. The PlexConnect version number. If using Github source then a time and date of download (look at the creation date of the folder) and if you are using any testing branch e.g. the Elan/PlexInc one.
- PlexConnect 0.1-iOs-pre5.1 (stated on the download)
9. The content of your 'Settings.cfg' file (if you do not have this file you are running an old version, please update)
- [PlexConnect]
- When I have gone through all the steps in the installation guide I and pressed the Trailer app in ATV3 I got the message "Trailers Unavailable.. ". Have read through large parts of the forum in the last 4 hours but no luck. I understand that it is a special case considering I have the Windows Server edition, but thought I could check if there were any suggestions to what I could do. I am also running VmWare, and as I read in the advanced section of the wiki that could prevent it from working. However, it does not give a detailed description of how to hardcode the location of your PMS(as the ip was wrong in the plexconnect log). I am not skilled what so ever in plex and coding in general, and therefore I wondered if anyone could assist me in how to hardcode into the settings file? Thank you so much in advance, the plexconnect is a brilliant piece of work and truly makes the ATV3 experience great.
