Trailers won't start on my Nvidia Shield - Error with audio codec? (more below)
I’ve filed the bug internally, just waiting to hear back.
Update : I noticed that trailers work in Watchlist while they keep crashing when i want to wach them from my librairies.
Any updates from your side ?
Yesteday i had 2 friends that came at my place. As they were interested in plex, i shown them how it is, they liked until they ask me to click on the trailer button… :confused:
So sad to have a premium feature like this broken.
For me the workaround here Trailers won't start on my Nvidia Shield - Error with audio codec? (more below) - #56 by Ripleya
works…
It’s still being looked at but the work around is to allow the trailer to transcode.
Sure… But until the issue is solved by Plex I deal with it.
Yes, but I don’t allow to transcode, so trailers doesn’t work.
Thanks for your efforts to help resolve this.
Hi @anon18523487, any new about plex fixing the broken trailers ?
I’m getting a bit angry when i see that plex is making a social network wannabe while not fixing what is broken.
Thank you for any update, we miss the trailers.
Hi, I also need the feature play trailer on the shield and would be happy if it gets fixed soon
Plex, you made a good job with Plex!
Don’t lose paying members like this. Provide already transcoded trailer versions for the top 10 device like Android and we are good.
Hi @anon18523487 , it seems that the last PMS beta update fixed the issue, trailers are back on my Shield!
@Ripleya , @JonSWEDEN @jej514 , could you confirm?
If it’s the case then we could mark this thread as solved :slight_smile:
EDIT :
Plex Media Server (Windows) version : 1.28.1.6041
Plex client (Shield) version : 9.6.2.34368
Hello, I can’t confirm that. With PMS 1.28.1.6041 (Windows) the trailers still don’t work on Shield with latest Plex app.
It still doesn’t work on shield pro 2019…
BUT…
I can confirm it now works on my Mi Box S with latest player beta v9.6.2.34368 and Latest PMS v1.28.1.6041 on my Synology NAS. But as said above, still not on the Shield.
Update: tried on my Mi Box again today just because and today it didn’t work, tried the same trailers that worked yesterday. Right now this seems to be more random and something is very buggy.
@viper_1 , @JonSWEDEN , here are the versions I use :
EDIT :
Unbelievable, it doesn’t work anymore!
I tried 3 trailers movies from my librairie (not Watchlist, not Discover) 2 hours ago and they all worked as expected. Now I see that it doesn’t work for you guys, I just retry to play those 3 same trailers, out of curiosity, and they doesn’t work anymore!
I even didn’t close my Plex session, i did nothing and they gone from playing to Impossible to read.
How the hell is that possible???
NVIDIA shield, still no Trailers
Just installed Plex client (Shield) version : 9.6.2.34368, and the newest Server.
My log:
Aug 09, 2022 22:55:29.037 [9000] Info — [Req#1b3e/Transcode] [FFMPEG] - MFT name: ‘Microsoft AAC Audio Encoder MFT’
Aug 09, 2022 22:55:29.042 [9000] Fehler — [Req#1b3e/Transcode] [FFMPEG] - Cannot load nvcuda.dll
Aug 09, 2022 22:55:29.042 [9000] Fehler — [Req#1b3e/Transcode] [FFMPEG] - Could not dynamically load CUDA
Aug 09, 2022 22:55:29.043 [9000] Fehler — [Req#1b3e/Transcode] [FFMPEG] - could not find any MFT for the given media type
Aug 09, 2022 22:55:29.043 [9000] Fehler — [Req#1b3e/Transcode] [FFMPEG] - could not create MFT
Aug 09, 2022 22:55:29.045 [9000] Warnung — [Req#1b3e/Transcode] Codecs: avcodec_open2 returned -40 for encoder ‘h264_mf’
Aug 09, 2022 22:55:29.048 [9000] Info — [Req#1b3e/Transcode] [FFMPEG] - MFT name: ‘Microsoft AAC Audio Encoder MFT’
and repeat…
Hahaha, wait a Moment: This is very funny.
FIRST, after restart it works for me…the Trailers are back. Than, after 5 Minutes or so, it wont work again on ANY movie. Wo way…
@kinde61 Are you running PMS on a 10gen Intel chip or newer? We are looking into an issue with those and hardware transcoding. Turn off hardware transcoding for now and it should work.
Hello MovieFan,
the Server runs on a Virtual Machine with Windows Server 2019 SD. The host ist an simple 8th gen Intel Ultra Cpu.
But a little win…it works with “Deaktiviere Video-Transcodierung”. All movies goes direct play (witch is okay) and the Trailers must be decoded.
Englisch (AAC Stereo)
OPUS—Umwandeln
1080p (H.264)
1080P (H264)—Umwandeln
WITHOUT unchecking this it wont work.
Huh. That’s the opposite of the issue we’ve seen. If you are running PMS in a Virtual Machine, you probably have a different issue. We don’t test PMS in a VM so it is not known what is expected.
So you had this “moment” too :smiley:
It worked for few hours and now it doesn’t anymore, what happened there?
