Trakt Mdeia Centre Settings
Under Preferences/Media Centre I am having problems to find the correct IP address to enter for Plex???
Usually its 127.0.0.1, if PMS is running on the same machine.
Not sure if you are Win, Mac or Linux user, but for win you can open command (run cmd) and type ipconfig /all and on Mac the easies way, is to open network in system preferences, and select your network interface
Running on OSX. IP of machine is 192.168.1.X. Which port do I use?
