Transcoder crashes when using subtitles
Hello
I have a Freenas running the PMS plugin, two Samsung smart TV’s with PMP. No matter which player I use, when I enable subtitles, the transcoder crashes. Even when playing in the web portal. With some movies, the subtitles work, but with most, the transcoder crashes. I’ve added my server log, which I downloaded right after the crash happened:
Plex Media Server Logs_2019-12-27_19-07-08.zip (5.8 MB)
Any pointers or help is welcome
Server Version#: Version 1.18.2.2058
Player Version#: Various
Welcome to the club. There’s quite a few of us experiencing this. I started having issues on my Freenas box with the first release of 1.18. Still waiting for a fix. I had to revert to 1.17 to get it working again. Did you try 1.18.4.2171?
Hello Scarygary71,
I have just updated to Version 1.18.3.2156, but the problem persists, so no luck there.
Hello
I am currently on version 1.18.6.2368, but the problem still persists Plex Media Server.log (1.1 MB)
I still have no clue as to what could cause this error.
Any help is very much appreciated
I checked the logs and I have exactly the same issues as described in this topic:
https://forums.plex.tv/t/pms-1-18-1-1973-freebsd-freenas-crashing-when-using-the-web-client-and-subtitles/480193/23
Still no solution found though
do you by any chance know where I can find the 1.17 release? It’s very annoying that it’s still not fixed
It is fixed. Or rather it took some tinkering and a little help from a few guys to figure it out. Check my other thread. I’m using the latest version (1.18.7.2415) right now and it works great.
Holy mother it worked. After all this time, a fix! Curious what this variable does actually
