Transcoder Errors - Moving back to NextPVR w/ Schedules Direct
Server Version#: 1.23.5.4841
Player Version#: (??? Server on Windows 10 19042.1110)
Tuner Make/Model: HDHomeRun Connect Quatro
Guide/Lineup name: Plex Default (Denver)
Using XMLTV?: No
Channel number/Name: 59.1 ION
Plex Media Server.1.log (10.1 MB)
I have a Plex lifetime subscription, but I have decided to abandon Plex as my PVR/DVR solution after several issues the past week that have really been occurring for almost a year now. ION television tends to show several episodes of a series back to back, and when the series episodes I record are on, it does not record full episodes ~10-20% of the time. I tracked it down to transcoder errors last night, and I have seen similar issues in previous posts that went unfixed.
The other issue I often have is if a recording fails due to a signal drop or transcoder error, Plex will hold onto that tuner. With four tuners available, I will often see three tuners still in use for episodes that should have completed several hours ago. HDHomeRun shows only one tuner in use, but Plex believes there are no tuners available and will fail to record beginnings of episodes because the one tuner was recording an overlap period.
I have attached a log file to see if Plex will provide any support for my issue. In the attached log file, the relevant recording is “Blue Bloods - E10 - Fathers and Sons” where several transcoder errors occur. Namely:
Jul 21, 2021 18:57:09.519 [10244] DEBUG - Content-Length of C:\Users\Ziggy\AppData\Local\Plex Media Server\Cache\Transcode\Sessions\plex-transcode-fd8f2929-f9be-4652-86e9-627074f21532\media-13371.ts is 698420 (of total: 698420).
Jul 21, 2021 18:57:09.519 [15636] DEBUG - Completed: [127.0.0.1:57084] 200 GET /livetv/sessions/fd8f2929-f9be-4652-86e9-627074f21532/ac82ffee-2c45-4f78-8363-e7dc5acdaa7a/13370.ts (16 live) 2ms 758956 bytes (pipelined: 129)
Jul 21, 2021 18:57:09.519 [15636] DEBUG - Removed transcode data consumer, active count 14405 => 14405
Jul 21, 2021 18:57:09.520 [15636] DEBUG - Completed: [127.0.0.1:62898] 200 GET /livetv/sessions/fd8f2929-f9be-4652-86e9-627074f21532/ac82ffee-2c45-4f78-8363-e7dc5acdaa7a/13371.ts (16 live) 1ms 698420 bytes (pipelined: 1757)
Jul 21, 2021 18:57:09.520 [15636] DEBUG - Removed transcode data consumer, active count 14405 => 14405
Jul 21, 2021 18:57:10.062 [10680] DEBUG - [Grabber/a3b4a646c94bc4b29801106a641fbb7be7dd164d] HTTP requesting GET http://192.168.86.124:80/discover.json
Jul 21, 2021 18:57:10.072 [10680] DEBUG - [Grabber/a3b4a646c94bc4b29801106a641fbb7be7dd164d] HTTP/1.1 (0.0s) 200 response from GET http://192.168.86.124:80/discover.json
Jul 21, 2021 18:57:10.072 [10680] DEBUG - [Grabber/a3b4a646c94bc4b29801106a641fbb7be7dd164d] HTTP requesting GET http://192.168.86.124:80/lineup_status.json
Jul 21, 2021 18:57:10.086 [10680] DEBUG - [Grabber/a3b4a646c94bc4b29801106a641fbb7be7dd164d] HTTP/1.1 (0.0s) 200 response from GET http://192.168.86.124:80/lineup_status.json
Jul 21, 2021 18:57:10.518 [11352] DEBUG - [Live/fd8f2929-f9be-4652-86e9-627074f21532/ac82ffee-2c45-4f78-8363-e7dc5acdaa7a] buildLiveM3U8: min 4370 max 13371 ended 0
Jul 21, 2021 18:57:10.560 [15232] DEBUG - [Transcode] Transcoder segment range: 4370 - 13372 (13372)
Jul 21, 2021 18:57:10.566 [11352] DEBUG - [Transcode] Transcoder segment range: 4370 - 13373 (13372)
Jul 21, 2021 18:57:10.781 [0872] DEBUG - Completed: [127.0.0.1:50343] 200 GET /player/proxy/poll?deviceClass=pc&protocolVersion=3&protocolCapabilities=timeline%2Cplayback%2Cnavigation%2Cmirror%2Cplayqueues&timeout=1 (16 live) GZIP 20014ms 5 bytes (pipelined: 27)
Jul 21, 2021 18:57:10.802 [0872] DEBUG - Auth: authenticated user 1 as Xilnik
Jul 21, 2021 18:57:10.802 [15232] DEBUG - Request: [127.0.0.1:50343 (Loopback)] GET /player/proxy/poll?deviceClass=pc&protocolVersion=3&protocolCapabilities=timeline%2Cplayback%2Cnavigation%2Cmirror%2Cplayqueues&timeout=1 (16 live) GZIP Signed-in Token (Xilnik)
Jul 21, 2021 18:57:10.802 [15232] DEBUG - Content-Length is -1 (of total: -1).
Jul 21, 2021 18:57:11.061 [7560] DEBUG - [Live/fd8f2929-f9be-4652-86e9-627074f21532/51767652-472b-4561-8b2f-d234b2894304] buildLiveM3U8: min 4370 max 13372 ended 0
Jul 21, 2021 18:57:11.062 [7560] ERROR - [Transcoder] http://127.0.0.1:32400/livetv/sessions/fd8f2929-f9be-4652-86e9-627074f21532/51767652-472b-4561-8b2f-d234b2894304/index.m3u8?offset=13382.617703&X-Plex-Token=xxxxxxxxxxxxxxxxxxxx: End of file
Jul 21, 2021 18:57:11.069 [10748] DEBUG - Jobs: 'C:\Program Files (x86)\Plex\Plex Media Server\Plex Transcoder.exe' exit code for process 15844 is 1 (failure)
Jul 21, 2021 18:57:11.069 [14044] DEBUG - [Grabber/a3b4a646c94bc4b29801106a641fbb7be7dd164d] TranscodeSession: session failed while waiting for duration
Jul 21, 2021 18:57:11.069 [14044] ERROR - [Grabber/a3b4a646c94bc4b29801106a641fbb7be7dd164d] Failed to start session.
Jul 21, 2021 18:57:11.069 [12376] DEBUG - Streaming Resource: Terminated session 119E1E98:51767652-472b-4561-8b2f-d234b2894304 with reason Recording failed. Please check your tuner or antenna.
Jul 21, 2021 18:57:11.069 [16200] DEBUG - Killing job.
Jul 21, 2021 18:57:11.069 [14044] ERROR - [Grabber/a3b4a646c94bc4b29801106a641fbb7be7dd164d] Recorder: Unable to create transcode session or session failed to start.
Jul 21, 2021 18:57:11.069 [16200] DEBUG - Job was already killed, not killing again.
Jul 21, 2021 18:57:11.069 [16200] DEBUG - Stopping transcode session 51767652-472b-4561-8b2f-d234b2894304
Jul 21, 2021 18:57:11.069 [14044] DEBUG - [Grabber/a3b4a646c94bc4b29801106a641fbb7be7dd164d] Job was already killed, not killing again.
Jul 21, 2021 18:57:11.069 [14044] ERROR - [Grabber/a3b4a646c94bc4b29801106a641fbb7be7dd164d] Recorder: Error 12 (There was a transcoder error) starting the record, shutting things down.
Jul 21, 2021 18:57:11.069 [14044] DEBUG - [Grabber/a3b4a646c94bc4b29801106a641fbb7be7dd164d] MediaRecorderVirtual: setting stop time to 2021-07-21 18:57:11
Jul 21, 2021 18:57:11.069 [14044] DEBUG - [Grabber/a3b4a646c94bc4b29801106a641fbb7be7dd164d] Grabber: Operation for 'Blue Bloods - E10 - Fathers and Sons' on channel 59.1 completed with status error (There was a transcoder error)
I have checked my antenna to see if a signal issue occurred during the transcoder errors, but I do not see any issues in the signal when I watch on HDHomeRun or NextPVR, hence why I am choosing to return to NextPVR for my television needs.
Is there any other information I can provide to help sort out these transcoder errors? If it helps, I am running HDHomeRun Quatro with the latest firmware: Version 20210624. Also, let’s assume that this is due to a bad signal, so the transcoder is failing to find a good stream of data to create the file. Why can’t it handle that differently, e.g. by filling missing segments with empty bytes?
I have seen several video editing solutions handle bad video the same way. I suspect that is how NextPVR’s transcoder handles similar issues since some of those videos sometimes have pixelated fluctuations due to a bad digital signal with black video in between the bad and good segments. Those segments are generally pretty short, and the streaming recovers much more robustly than Plex’s system does for some reason.
