@ChuckPa @anon18523487
Can you tell me if this error is disk or network related…
Jul 22, 2021 00:32:41.762 [0x7f97fad8bb38] ERROR - [Transcoder] http://10.1.1.75:34400/stream/84fd58299f23b8eb66c867948f263315: I/O error
Jul 22, 2021 00:32:41.765 [0x7f97fefa5b38] DEBUG - Jobs: ‘/usr/lib/plexmediaserver/Plex Transcoder’ exit code for process 812 is 1 (failure)
Jul 22, 2021 00:32:41.765 [0x7f97fdf8fb38] DEBUG - Killing job.
It’s streaming a remote stream but I know it saves it to the disk. I’m just not sure exactly what this I/O error is referring to. Can you get the low down for me…
Can’t tell from an excerpt that small.
DEBUG logs ZIP file please which capture it?
(Best logs would be to restart Plex, wait 2 minutes, then recreate the failure )
Here is a full log with the error displayed twice. Search for I/O error.
The situation is killing me with this Live TV. I can view the remote streams in VLC without issue. I can even be watching the stream in VLC at the same time Plex will fail and VLC will still be running smooth.
May I please have the FULL zip? It does me no good to start in the middle of something. I WANT to see PMS start. There is a reason for my request.
removed file
This is all I have. There is no set way to recreate the error. It is random. Could be hours could be minutes before it happens.
