Can someone please let me know why this error occurs while trying to play on my server plex transcoder i/o error.
This is very recent and am not sure why this is happening.
Please let me know if you have faced this and have resolved it.
Need the DEBUG log ZIP file please which capture it happening.
(sorry, we can’t diagnose properly and give help without seeing the details)
Hi, Thanks for getting back so quick.
I have attached the Debug Log file in zip which has captured the issue.
plex_media_server.log.zip (21.6 KB)
Is this it?
May 30, 2022 21:27:25.554 [0x7fadb33bbb38] Debug — [Notify] Now watching "/mnt/plex/Movies - English/In Heaven There Is No Beer! (1984)"
May 30, 2022 21:27:25.673 [0x7fadb167bb38] Error — [Transcoder] /mnt/plex/TV Shows/Stranger Things/Season 4/Stranger Things - S04E03 - Chapter Three - The Monster and the Superhero.mkv: I/O error
May 30, 2022 21:27:25.674 [0x7fadb5c4bb38] Debug — Jobs: '/usr/lib/plexmediaserver/Plex Transcoder' exit code for process 4308 is 1 (failure)
May 30, 2022 21:27:25.674 [0x7fadb1e58b38] Debug — Streaming Resource: Terminating session 0x7fadb5bdd4a8:94dvrgfzatvkm7dyqkq84o3e which is using 12797kbps of WAN bandwidth. Used is now 42673kbps
May 30, 2022 21:27:25.674 [0x7fadb0fb2b38] Debug — [Transcode] Using default transcode duration of 120 minutes
May 30, 2022 21:27:25.674 [0x7fadb0fb2b38] Debug — [Transcode] Started session successfully: 2r2dcjleaojyqyd0qhf5oejk
May 30, 2022 21:27:25.675 [0x7fadb1e58b38] Debug — Streaming Resource: Terminated session 0x7fadb5bdd4a8:94dvrgfzatvkm7dyqkq84o3e with reason Conversion failed. The transcoder exited due to an error.
May 30, 2022 21:27:25.675 [0x7fadab79fb38] Debug — Killing job.
The transcoder got an I/O error reading the source file from
if a network connection, and the connection went stale , you’d get this error.
you’d also get this error if a USB drive which didn’t spin up in time.
Yes, thats the one.
So I did restart the server and updated the mount point as well, its still the same.
The next step is to try and copy the file… see if it can actually be read and copied to some other location (as a test)
This seems to work, I have updated the mount and its working fine now. Thank you for the help ![]()
