Transcoding crashing on Nvidia T4 GPU
Damn this card looks clean tho
I have a RTX A5000, I’ll try with it too but I’ve seen that you can do less transcode session than the T4 that’s why I wanted to use the T4 on this server :rofl:
Always check the release date and specs.
They love to change the numbers and add letters like “A” – haha
I have the rtx2000 ada because of the AV1 work I’ll be doing
I’ll be carefull so !
I’m curious, how do you get your content to AV1 you’re converting it ? Because I can see that your card can’t encode to AV1.
How many transcodes you can get with AV1 and your card ?
Look again.
“RTX 2000 ada generation” . Released 2024
It has dedicated AV1 encoding onboard.
I don’t use the encoder yet. I’m primarily using the card for our FFMPEG upgrade work. (FFMPEG 4 → FFMPEG 6.1)
After things stabilize with all the other transcoding upgrades, Then we will address AV1 encoding for those capable GPUs and players
