Transcoding fails with VOBSUB subtitles
Server Version#: 1.40.1.8227 (Ubuntu 22.04.4 LTS)
Hello! I’m running into an issue where transcoding fails anytime I play back a media file with VOBSUB subtitles. Plex gives me an error like this:
Conversion failed. The transcoder exited due to an error.
This happens when I try playback using Plex Web on macOS, Windows, and also the Plex app on iOS. Oh, and also on Shield TV Pro. The server shows errors like this:
[Req#23b50ed/Transcode/dg9wvxhetocdzn9808hraanw/c8d6dec5-cb7d-41cd-984a-23112867d2aa] [vobsub @ 0x7fe29e10bd00] Unable to open /home/media/plextmp/Transcode/Sessions/plex-transcode-dg9wvxhetocdzn9808hraanw-c8d6dec5-cb7d-41cd-984a-23112867d2aa/temp-0.sub as MPEG subtitles
[Req#23b50f0/Transcode/dg9wvxhetocdzn9808hraanw/c8d6dec5-cb7d-41cd-984a-23112867d2aa] /home/media/plextmp/Transcode/Sessions/plex-transcode-dg9wvxhetocdzn9808hraanw-c8d6dec5-cb7d-41cd-984a-23112867d2aa/temp-0.idx: No such file or directory
The files play back fine when I disable subtitles, or switch to SRT so it’s really just VOBSUB that trips it up. Server is Ubuntu 22.04 with an i5-7600K with hardware transcoding enabled, playback/transcoding happens fine in all other circumstances.
On my server, I run the plexmediaserver service as user media, and my transcoding temp directory is /home/media/plextmp. Both the media and plex users have full read/write here. The volume is a 500GB NVMe drive that’s only 1% full.
I made a post over on Reddit about it and someone suggested I stop PMS, clear the codecs directory (/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Codecs in my case), and restart PMS to allow new downloads of the latest codecs. However, my folder was empty and even after stopping/starting, it’s still empty. I was directed here to ask, so here I am.
This is not a huge issue since playback happens just fine when I don’t enable VOBSUB subtitles, but I’m real curious if this can be fixed and now I’m far enough down the rabbit hole. Should I be concerned that there’s no codecs installed, is there a way to force them in there or do I need them? Thanks!
May I have the server DEBUG LOGS zip file which captures this error please ?
Plex Media Server Logs_2024-04-19_11-06-47.zip (733.6 KB)
Here you go, this should have everything.
@lordtaco
  1. Bad “Allowed Networks” value
Apr 19, 2024 06:25:12.602 [139759308032656] INFO - Running forward migration 202401290807.
Apr 19, 2024 06:25:12.609 [139759296355128] ERROR - Error parsing allowedNetworks entry '172.16.0^@12': Invalid argument [system:22]
Apr 19, 2024 06:25:12.614 [139759308032656] INFO - Completed forward migration 202401290807.
These are ERROR/INFO logs.
You forgot to hit SAVE after enabling DEBUG logging.
Might be a good idea to fix the network setting, enable & save DEBUG logging, then restart PMS and retest
Thanks. I corrected the allowedNetworks entry, enabled debug logging, and restarted and duplicated the issue.
Do I have the correct ZIP file?
I still see both the error and no DEBUG logging.
Apr 19, 2024 06:25:12.541 [139759308032656] INFO - Completed forward migration 202401290803.
Apr 19, 2024 06:25:12.541 [139759308032656] INFO - Running forward migration 202401290804.
Apr 19, 2024 06:25:12.548 [139759308032656] INFO - Completed forward migration 202401290804.
Apr 19, 2024 06:25:12.548 [139759308032656] INFO - Running forward migration 202401290805.
Apr 19, 2024 06:25:12.595 [139759308032656] INFO - Completed forward migration 202401290805.
Apr 19, 2024 06:25:12.595 [139759308032656] INFO - Running forward migration 202401290806.
Apr 19, 2024 06:25:12.602 [139759308032656] INFO - Completed forward migration 202401290806.
Apr 19, 2024 06:25:12.614 [139759308032656] INFO - Running forward migration 202401290808.
Apr 19, 2024 06:25:13.745 [139759308032656] WARN - Held transaction for too long (/home/runner/actions-runner/_work/plex-media-server/plex-media-server/Library/DatabaseMigrations.cpp:293): 1.090000 seconds
Apr 19, 2024 06:25:14.005 [139759308032656] INFO - Completed forward migration 202401290808.
Apr 19, 2024 06:25:14.005 [139759308032656] INFO - Running forward migration 202402260801.
Apr 19, 2024 06:25:14.012 [139759308032656] INFO - Completed forward migration 202402260801.
Well, heck I’ll try again. I have debug logging enabled on the server. Lemme figure it out.
Confirming
Settings - Server - General (tab) - Show Advanced
