Server Version#: v1.41.8.9834 Ubuntu 22.04.5
Hello! I’m running into an issue where transcoding fails anytime I try to optimize a media file with VOBSUB subtitles.
The files play back fine when I disable subtitles, or switch to SRT so it’s really just VOBSUB that trips it up.
attached log shows the error that occured during optimizing both for TV and Mobile
Plex Media Server.log (2.7 MB)
it seems to be the same issue as mentioned here, and i’ve also followed all the steps that they mentioned: Transcoding fails with VOBSUB subtitles
Looking at the log file (thanks for providing), I see:
- PMS sees the card on the PCI bus as it starts
- PMS loads the drivers for it
- HOWEVER, PMS can’t access it to use it for transcoding
Is PMS running as user plex or some other user ?
PMS is indeed running as user plex
> ps aux | grep plex
plex 134609 0.6 0.8 210820 70412 ? Ssl Jun17 1:16 /usr/lib/plexmediaserver/Plex Media Server
plex 134643 0.1 0.5 64844 43224 ? SNl Jun17 0:15 Plex Plug-in [com.plexapp.system] /usr/lib/plexmediaserver/Resources/Plug-ins-071366d65/Framework.bundle/Contents/Resources/Versions/2/Python/bootstrap.py --server-version 1.41.8.9834-071366d65 /usr/lib/plexmediaserver/Resources/Plug-ins-071366d65/System.bundle
plex 134683 0.1 0.1 43932 12488 ? Sl Jun17 0:24 /usr/lib/plexmediaserver/Plex Tuner Service /usr/lib/plexmediaserver/Resources/Tuner/Private /usr/lib/plexmediaserver/Resources/Tuner/Shared 1.41.8.9834-071366d65 32600
plex 135452 2.1 0.0 2596 1176 ? S Jun17 3:50 Plex EAE Service
i also forgot to mention that other files are successfully being transcoded, using “optimize for TV”
Please check for me?
ls -la /dev/dri
groups plex
Copy the text and paste to a code (preformatted text) block .
Do you also have the idx file? Vobsub subtitles won’t work without them.
❯ ls -la /dev/dri
total 0
drwxr-xr-x 3 root root 100 Jun 12 10:48 .
drwxr-xr-x 19 root root 4560 Jun 13 00:34 ..
drwxr-xr-x 2 root root 80 Jun 12 10:48 by-path
crw-rw---- 1 root render 226, 0 Jun 12 10:48 card0
crw-rw---- 1 root render 226, 128 Jun 12 10:48 renderD128
❯ groups plex
plex : plex video render
yep, they are in the same folder as the .sub files. the files are correct, Plex can also use them while transcoding on-the-fly:
AFAIR external VOBSUBs are like asking or trouble.
mmkay, but who/what is to blame? is this a fault/bug in PMS?
just declaring “VOBSUB are trouble” doesn’t seem very productive..
I don’t know the inner workings of Plex server so intimately that I am able to point the finger.
Just that in the 11 years I’ve been using it and participating in this forum, that external VOBSUB always meant trouble.
Just try to mux them in as an experiment. See if the behaviour changes.
MKVtoolnixGUI
try to burn them in using an external tool, so that Plex doesn’t need to do that anymore? obviously that will work. but that’s not a solution…
a real solution would be to fix PMS… no? (or help me help you fix PMS, like ChuckPa seems to be doing)
I don’t mean burning in the subtitles into the video picture.
Multiplexing the subtitle stream into the same file as the video and the audio doesn’t change the video.
The subtitles remain “soft”, i.e. they can be enabled and disabled just like before.
Just that there is now only one file, instead of two.
ohh. i’m sorry, i didn’t understand your request..
i’ll have a look at it…
