Transcoding in TS 873A - GTX1650
Hardware Transcoding doesn’t work in TS873A
Server Version#: 1.25.4.5468
Plex Media Server Databases_2022-01-29_18-49-12.zip (2.1 MB)
1.25.4.5468
Plex Media Server Logs_2022-01-29_19-46-29.zip (4.2 MB)
Based on everything I could find about that model, it doesn’t support Plex HW-accelerated transcoded
Thank you for your reply.
Can I force the hardware decoding function to be enabled through configuration? Try customizing the reference.xml。
You can’t.
Plex is using Intel QSV and your NAS seems to use an AMD CPU – even if that has an iGPU, it appears Plex isn’t supporting that.
