Server Version#: latest
Player Version#: latest
Hi guys, I share my PMS with a friend who’s have the latest Fire Stick TV (2020). This one uses android tv and it happens more than often that do not direct play but instead transcodes without a real necessity. I also tried to play the same movie from home (in local network) with a fire stick tv older than hers, and it direct played. She have remote quality setting to maximum and I also told her to try to change H264 level to 5.0 (from 4.2 if i remember correct).
But it didn’t work and she still transcode with some movies.
I found these lines in logs, I don’t know if it can help:
Jan 09, 2021 23:02:03.011 [29060] ERROR - [Transcode] [FFMPEG] - cu->cuCtxCreate(&hwctx->cuda_ctx, 4, cu_device) failed
Jan 09, 2021 23:02:03.011 [29060] ERROR - [Transcode] [FFMPEG] - -> CUDA_ERROR_UNKNOWN: unknown error
Jan 09, 2021 23:02:03.011 [29060] DEBUG - [Transcode] Codecs: hardware transcoding: opening hw device failed - probably not supported by this system, error: Unknown error occurred
Jan 09, 2021 23:02:03.011 [29060] DEBUG - [Transcode] Scaled up video bitrate to 2143Kbps based on 1.500000x fudge factor.
Jan 09, 2021 23:02:03.011 [29060] DEBUG - [Transcode] MDE: Captain Fantastic (2016): selected media 0 / 214699
Jan 09, 2021 23:02:03.011 [29060] DEBUG - [Transcode] Streaming Resource: Adding session 0x8ca37d8:e60a894e7396e06e-com-plexapp-android which is using 2721kbps of WAN bandwidth. Used is now 2721kbps
Jan 09, 2021 23:02:03.011 [29060] DEBUG - [Transcode] Streaming Resource: Adding session 0x8ca37d8:e60a894e7396e06e-com-plexapp-android which is using transcoder slot. Used slots is now 1
Jan 09, 2021 23:02:03.011 [29060] DEBUG - [Transcode] Streaming Resource: Added session 0x8ca37d8:e60a894e7396e06e-com-plexapp-android
Jan 09, 2021 23:02:03.011 [29060] DEBUG - [Transcode] Streaming Resource: Reached Decision id=138081 codes=(General=1001,Direct play not available; Conversion OK. Direct Play=3000,App cannot direct play this item. Direct play is disabled. Transcode=1001,Direct play not available; Conversion OK.) media=(id=214699 part=(id=322258 decision=transcode container=mpegts protocol=hls streams=(Video=(id=542840 decision=transcode bitrate=2143 encoder=h264_mf width=688 height=288) Audio=(id=542841 decision=copy channels=6 rate=48000))))
