I’m having a strange issue with the “convert automatically” quality setting where it won’t start playing (all I get is the poster with the loading spinner). This is happening for multiple clients (I’ve tested on my Android phone and Nvidia Shield) which makes me wonder if there’s a setting I’m missing on my server.
To clarify, transcoding on my server is working fine. If I select a specific quality, I can start streaming right away with no issue. If I have “convert automatically” selected and try play something (which doesn’t work), and then change to a specific quality setting in the playback settings, it plays fine. If I then change it back to “convert automatically,” it’s hit or miss – sometimes it keeps playing, sometimes I get the spinner again.
For reference, I’m running the linuxserver docker image (version 1.28.2.6106) on Ubuntu 22.04 LTS on an Intel 11th gen NUC (i5-1135G7 processor) with 16 GB of RAM.
Any suggestions would be greatly appreciated!
Some additional details on my server settings in case it helps:
- Transcoder quality is set to automatic
- Hardware acceleration is enabled (and I do see the “hw” in Tautulli when transcoding)
- Background transcoding x264 preset is set to “very fast”
- HDR tonemapping is enabled
