Transfer files over local network - No longer working?
Same issue here. Transfer over network stuck on LOADING. Also, there is not an option to Store Server on my mounted SSD anymore.
I forced uninstall updates of both Server & App hoping a fresh update would fix the issue. NO. Still no option to store on drive. And when I try to recreate my libraries the option for Premium Music Service is now missing as well (I am a lifetime Plex Pass holder). What a mess.
For a little while I had a fantastic new interface which included the ability to add plugins and changing storage location was available then suddenly everything was gone and/or not working
I’m also experiencing this and it’s as frustrating as hell. What sort of testing is done prior to releases, as this isn’t the first time that we’ve been trapped in bear-pit hell with some upgrade that never gave any indication it was about to cause issues?
Are Smoke Tests done? Are Unit Tests done? Are Functional Tests done? I’m becoming sorely disappointed with the Plex experience and considering after years of being a Plex Pass Holder, switching to Emby as I have a colleague who doesn’t have nearly as much of an issue, and actually gets acknowledgements from the Developers when problems are raised.
Fix this, and please fix it fast as it’s really getting the community’s back up.
I’m another victim. File Transfer impossible on 1.15.6.1090 on Nvidia Shield
It would be nice to get some DEV feedback on this…
I wish beta software was more stable.
I get that it’s beta, but it shouldn’t break basic functionality.
Just a heads up… There is a test version of the latest Nvidia Shield firmware 7.2.3(30.6.131.8) that you can get by putting in your SN into a website.
This does NOT fix this issue… if anyone else was tempted to install that to see if it fixes it.
That is all.
Nothing new to add here. Just chiming in that I have the same problem after the update was applied. Hoping for an update to repair the issue rather than stepping backwards.
Updated the server to Version 1.15.8.1126 and it works again :sonriendo: Many thanks!
Just to confirm, this worked for me too. Thank you.
Working for me too
The overall SMB functionality is back, but I encounter a (timeout?) error for directories that contain a large number of files. Specifically, mounting the external storage of the Shield on macOS Mojave through Finder and then exploring a directory that holds > 20000 files does not yield any output. Resorting to the terminal and trying to list the directory contents with that results in zero output after the ā€œlsā€ command terminates roughly after 20 seconds. Other folders that contain only hundred(s) of files work fine in both cases…
I did not yet test whether this is specific to macOS as client, but would not expect it to be.
SMB issue fixed but now alexa voice commands no longer work, anyone else?
Me. Buts that’s another ticket
Sounds like a worthwhile security enhancement to me (breaking it), but others obviously feel differently :slight_smile:
Other than that 1.15.8.1126 seems pretty solid for me so far …
Hi @StephenH,
Before I start a new thread on my ā€œinvisible large directoryā€ issue, I wanted to ask you whether the same problem that I am experiencing (silent timeout on large directories) happens on your end?
To test this, I would open up Terminal, navigate to your Shield-SMB-mount, i.e.
cd /Volumes/name-of-SHIELD-SMB-mountpoint
and then create a directory with a bunch of (empty) files in it:
mkdir lots-of-files; for id in {0..20000}; do touch lots-of-files/${id}.empty; done
In my case, neither
ls lots-of-files
nor browsing of this newly created folder ā€œlots-of-filesā€ in Finder shows any content but silently ignores the request…
Thanks a lot.
@eisenlohr I’ll try a test hopefully sometime tomorrow (just gone midnight here in Australia) and report back if I can. All my machines are still on 10.13.6 so not sure if that will make a difference?
Latest update resolved my network (smb) issue but I still don’t have the Premium Music Service Option.
@eisenlohr
Just reporting back. I can’t reproduce your ā€œfaultā€.
I created 2000-odd files on my Shield internal 500 GB drive (I have a Shield Pro 2017) and I can see them all, both in Terminal using ā€œlsā€ and also in Finder.
Suggest you open a new Topic so we don’t drag this one off track any further?
Yea! Working for me again as well!
