Transfer Media Between Plex Servers
Is there an option to transfer media between two PMS with the detail of content rating? For example I have a WD My Passport used for road trips with the kids tablets. Primarily want to load the WD device with kids content. Rather then pick through a list of files from file explorer it would be awesome if I could just transfer the “kids” content.
Similar to the below post.
Yeah, it’s called mobile sync. https://support.plex.tv/articles/201543257-what-is-mobile-sync/
I believe mobile sync is not what I am looking for…the device I am trying to “sync” with is a Western Digital My Passport running another instance of PMS. This solution is supported by PLEX for a mobile PMS.
Oh sorry. Misread your comment. Thought you just wanted to use the tablets. If you are using the MyPassport, there is no quick way to transfer files from another PMS. You’ll have to do it manually.
No problem.
