Summary:
I currently have PMS (Plex Media Server) running on a Windows 10 machine with around 20 TB of data media. Well into the thousands of videos and shows. What I would like to do is transition this PMS to an UnRaid system. I’m not quite sure on how to get there or the best approach. I could really use some help.
What I would like to do:
- Migrate the metadata from the Windows PMS to the Unraid PMS so it doesn’t have to spend hours downloading all the new data.
- Downtime? There is no way to do an online sync and then flip one off, then the other takes over?
- Internal IPs and user issues - I want to make sure users (family) is not affected by me changing stuff on my end. It should be as seamless as possible.
I need to enable Hardware transcoding on PMS Unraid to allow my Nvidia P2000 to offload.
What I have done:
UnRaid is installed on a server.
I have copied over all the data to the UnRaid system.
I have NOT installed PMS yet on the UnRaid system.
I’m running the latest version of PMS.
