Howdy! It would be nice to have a setting for each Library that allowed a user to traverse the folders of the library. I have a ton of training videos and they are all named 01 $Description, 02 $Description, etc., across a ton of folders, so it isn’t easy for me to watch a specific folder in order. Allowing users to traverse the folders would resolve this issue.
What client are you using? Some clients have a “Folder View” already.
You could also try naming your videos so they display properly in a Show/Season with a TV Show library: https://support.plex.tv/hc/en-us/articles/200265256-Naming-Home-Series-Media
That would work on the broadest range of clients.
I’m using the Android and FireOS clients. I’ll look for the folder view to see if it’s there, never noticed it before.
Thanks!!
Shawn
I know Plex/Web and PHT have it, I haven’t used either of those clients so couldn’t say for sure.
And it does exist … just had to look for it a bit harder. Many thanks!!
Glad you got it figured.
