Tried to look switch between NAS server and computer server and Plexamp lost site of computer?
Server Version#: 4.116.1
Player Version#: Plexamp 4.9.2
I am setting up a NAS. I wanted to test out the NaS connection (Synology) to my Plexamp remotely. When I opened Plexamp and saw two options (computer =Shartbox, NAS=Jukebox) and chose Jukebox, Shartbox completely disappeared. Once I was off my local network I couldn’t access anything on Jukebox (I still have some stuff to figure out) but couldn’t switch back to Shartbox. I had to uninstall the app, then reinstall it, while turning off remote access for Juke.
Why can’t I just flop back and forth between the two?
Plexamp-Logs-2023-12-13-2.zip (801.7 KB)
I don’t understand where you’re trying to switch between the two, but you have an issue with “Shartbox” not being properly configured to be available remotely:
Dec 13, 2023 08:51:29.750 [Javascript] WARNING - DEVICE: Server connection https://104-187-187-130.e55dd77a890940afb7f730368b4a5873.plex.direct:32400 didn't work for ShartBox: HTTP status -28
Make sure your Plex web page is showing it green and accessible, and if it is, then your mobile carrier might be blocking and you should change to a port other than 32400 like 443 or 8443.
