Troubleshoot
Unable to play video on desktop or Xbox. I keep getting the message:
“Please check that the file exists and the necessary drive is mounted.”
Have optimized database, cleaned bundles, refreshed/scan library.
Restarted, got latest version - no change.
Any advice appreciated.
(Windows 10 PC, XBOX One)
Will the file plsy if you double click on it in the Windows file system?
yes, if I go direct it will play as normal.
See My Plex has stopped working
Marvellous!!
thanks OttoKerner
