Having taken time to experiment with what we did, and think more about what’s happening to you, there are two issues here.
We have solved, with a patch, your Notify problem.
One is still outstanding. which is intermittent.
Jan 25, 2019 22:43:20.108 [0x7fc51c623700] DEBUG - Completed: [192.168.1.131:51650] 200 GET /:/timeline?bandwidth=976&bufferedTime=0&containerKey=%2FplayQueues%2F278&duration=6072900&guid=com.plexapp.agents.imdb%3A%2F%2Ftt2911666%3Flang%3Den&key=%2Flibrary%2Fmetadata%2F84063&machineIdentifier=1e62c8b6e06f13a60ab056ecdbbe16b1b3f56d30&playbackTime=0&playQueueItemID=3292&ratingKey=84063&state=buffering&time=0 (10 live) GZIP 10ms 710 bytes (pipelined: 6)
Jan 25, 2019 22:43:20.246 [0x7fc516bff700] DEBUG - NetworkInterface: received Netlink message len=1204, type=RTM_NEWLINK, flags=0x0
Jan 25, 2019 22:43:20.246 [0x7fc516bff700] DEBUG - NetworkInterface: Netlink information message family=0, type=1, index=14, flags=0x1002, change=0xffffffff
Jan 25, 2019 22:43:20.247 [0x7fc516bff700] DEBUG - Network change.
Jan 25, 2019 22:43:20.247 [0x7fc516bff700] DEBUG - NetworkInterface: Notified of network changed (force=0)
Jan 25, 2019 22:43:20.256 [0x7fc516bff700] DEBUG - Network change notification but nothing changed.
Jan 25, 2019 22:43:20.256 [0x7fc516bff700] DEBUG - NetworkInterface: received Netlink message len=1208, type=RTM_NEWLINK, flags=0x0
Jan 25, 2019 22:43:20.256 [0x7fc516bff700] DEBUG - NetworkInterface: Netlink information message family=0, type=1, index=14, flags=0x1043, change=0x1
Jan 25, 2019 22:43:20.256 [0x7fc516bff700] DEBUG - Network change.
Jan 25, 2019 22:43:20.256 [0x7fc516bff700] DEBUG - NetworkInterface: Notified of network changed (force=0)
Jan 25, 2019 22:43:20.257 [0x7fc516bff700] DEBUG - Network change notification but nothing changed.
Jan 25, 2019 22:43:20.257 [0x7fc516bff700] DEBUG - NetworkInterface: received Netlink message len=1208, type=RTM_NEWLINK, flags=0x0
Jan 25, 2019 22:43:20.257 [0x7fc516bff700] DEBUG - NetworkInterface: Netlink information message family=0, type=1, index=14, flags=0x1003, change=0x0
Jan 25, 2019 22:43:20.257 [0x7fc516bff700] DEBUG - Network change.
Jan 25, 2019 22:43:20.257 [0x7fc516bff700] DEBUG - NetworkInterface: Notified of network changed (force=0)
Jan 25, 2019 22:43:20.258 [0x7fc516bff700] DEBUG - Network change notification but nothing changed.
Jan 25, 2019 22:43:20.269 [0x7fc516bff700] DEBUG - NetworkInterface: received Netlink message len=1208, type=RTM_NEWLINK, flags=0x0
Jan 25, 2019 22:43:20.269 [0x7fc516bff700] DEBUG - NetworkInterface: Netlink information message family=0, type=1, index=14, flags=0x1003, change=0x0
Jan 25, 2019 22:43:20.269 [0x7fc516bff700] DEBUG - Network change.
Jan 25, 2019 22:43:20.269 [0x7fc516bff700] DEBUG - NetworkInterface: Notified of network changed (force=0)
Jan 25, 2019 22:43:20.278 [0x7fc516bff700] DEBUG - Network change notification but nothing changed.
Jan 25, 2019 22:43:20.279 [0x7fc516bff700] DEBUG - NetworkInterface: received Netlink message len=1232, type=RTM_NEWLINK, flags=0x0
Jan 25, 2019 22:43:20.279 [0x7fc516bff700] DEBUG - NetworkInterface: Netlink information message family=0, type=1, index=14, flags=0x1003, change=0x0
Jan 25, 2019 22:43:20.279 [0x7fc516bff700] DEBUG - Network change.
Jan 25, 2019 22:43:20.279 [0x7fc516bff700] DEBUG - NetworkInterface: Notified of network changed (force=0)
Jan 25, 2019 22:43:20.280 [0x7fc516bff700] DEBUG - Network change notification but nothing changed.
Jan 25, 2019 22:43:20.280 [0x7fc516bff700] DEBUG - NetworkInterface: received Netlink message len=1232, type=RTM_NEWLINK, flags=0x0
Jan 25, 2019 22:43:20.281 [0x7fc516bff700] DEBUG - NetworkInterface: Netlink information message family=0, type=1, index=14, flags=0x1003, change=0x100
Jan 25, 2019 22:43:20.281 [0x7fc516bff700] DEBUG - Network change.
Jan 25, 2019 22:43:20.281 [0x7fc516bff700] DEBUG - NetworkInterface: Notified of network changed (force=0)
Jan 25, 2019 22:43:20.281 [0x7fc516bff700] DEBUG - Network change notification but nothing changed.
This resulted in PMS not being able to authenticate for the TrueHD codec right after it had authenticated you as the owner/user. Error 6 is a DNS lookup (resolve name to IP address) error.
Jan 25, 2019 22:43:29.582 [0x7fc514048700] DEBUG - HTTP requesting PUT https://plex.tv/api/servers/1e62c8b6e06f13a60ab056ecdbbe16b1b3f56d30/connectivity?X-Plex-Token=xxxxxxxxxxxxxxxxxxxx&asyncIdentifier=4dd2605a-d1c0-4569-882b-636e5f75d61a
Jan 25, 2019 22:43:29.651 [0x7fc515bff700] ERROR - Error issuing curl_easy_perform(handle): 6
Jan 25, 2019 22:43:29.651 [0x7fc515bff700] WARN - HTTP error requesting GET https://plex.tv/api/v2/release_channels?X-Plex-Token=xxxxxxxxxxxxxxxxxxxx (0, No error) (Couldn't resolve host 'plex.tv')
This isn’t good nor was it there previously. Your network (LAN) is going up/down like a yo-yo resulting in DNS lookup failures. My first words are to check the integrity of the connectors and ethernet cables. I have had the locking clip break off more than once or not fully lock in. Not locking in properly is usually the case and it slowly slips out over time.
Please take a look and this and verify mechanical settings.
Also, as secondary check, have DSM check for updates. This will further validate it can see the internet correctly.
