TrueHD silent audio, I finally found a solution
I have some ripped BD movies in a mkv container.
The XBOX Plex client does passthrough TrueHD audio of half the files I have. Analysing the difference among them using MediaInfo, I found out that in the ones which worked, the TrueHD audio track was always the first ID in the audio track list.
So, using MKVToolNix I simply switched the order of the audio tracks, ensuring TrueHD track went first always. And to my surprise it WORKED! Passthrough happened flawlessly with every audio track.
All I need the client to have now is support for native image-based subs.
I hope it helps.
Glad you figured it out.
HERE is some previous discussion on this same issue.
THANK YOU!
Can confirm this fixed the issue for me. I did the same and made the TrueHD track first on the list and it worked straight away.
