Trying Plex Media Player
I want to have a look at Plex Media Player for my Pi2. I have been running Rasplex 0.7.1 for a while and am pretty happy with it. Can I just swap out the memory card for a new one with a fresh install of PMP?
Would I be able to just swap them out as needed. I want to test out PMP but put Rasplex back on at night so my family doesn’t freak out :wink:
Thanks.
Thanks.
Yep, no problems in doing that, don’t forget to ‘Shutdown’ the RPi before pulling power.
Regards
sorry for jumping in this conversation… I’m running RasPlex 0.7.1 too…
How can I try this new PlexMediaPlayer on my Ransperry Pi2??
Have you a link to read something Erlin?
Moreover…do you know if it will work with a plex media server installed on a Synology DS214play?
Marco
Just download and flash a different SD card with PMP (see https://support.plex.tv/hc/en-us/articles/208050647-Getting-Started) then swap out your SD card with the one you have Rasplex on, if you find you prefer Rasplex, swap the cards back.
Regards
It was easy enough to get it up and running. However I just found out that PMP does not support the VC-1 codec for BluRay rips. I need to do some more testing with uncompressed BluRay rips that are not VC-1 encoded.
Also there is no “shutdown” function anywhere in PMP :wink:
Yes, there is.
Go back to the home screen, press ‘Return’ (at least that is the button I use on my CEC compatible remote).
If you have a USB keyboard on your Pi you can also use Esc or Backspace.
@erlin@mac.com @OttoKerner
Can I suggest that you take any further discussion on Plex Media Player across to its own forum, this is after all the Rasplex forum.
