As the topic states im trying to figure out why all of a sudden , my users with Samsung TV seems to be transcoding when streaming from my server.? Normally they are streaming without transcoding, but now I see “transcoding h264 to h264” ?
My current upload speed is testet to 61 Mbps = 7.625 MB/s which should be plenty for streaming without any issues? Never had any complaints so far , so no buffering etc. Dont know if its because the server never have made a “Perform extensive media analysis during maintenance” ? My server is not online at night, only during evening. So the scheduled task never runs. Can it have something to do with that? I read a note:
“Note: If the deep analysis for a file hasn’t yet been performed, your Plex Media Server will assume a [2 x average bitrate] value if it’s needed for streaming limitation calculations.”
How long time does the server needs to make this analysis for my media files? I have aprox 8TB data .
My server settings is set to the following:
Server:
Remote Access:
Internet upload speed 61Mbps
Limit remote stream bitrate ( Original (no limit) )
Network:
Remote streams allowed pr user ( Unlimited )
Transcoder:
Transcoder settings haven’t been touched at all.
Web
As I understand its for streaming from server to a webbrowser, correct?
Quality:
Internet Streaming , Video Quality 4Mbps, 720p
Enabled: Play smaller videos at original quality
Enabled: Use recommended settings
Here is an example of a media file. ( If I stream this over LAN, its not transcoding at all )
Media
Video Resolution 1080p
Duration 1:16:57
Bitrate 9545 kbps
Width 1920
Height 1080
Aspect Ratio 1.78
Container MKV
Video Frame Rate 24p
Audio Profile dts
Video Profile high
Part
Duration 1:16:57
Size 5.13 GB
Audio Profile dts
Container MKV
Video Profile high
Codec H264
Bitrate 6601 kbps
Language English
Bit Depth 8
Chroma Subsampling 4:2:0
Frame Rate 23.976 fps
Height 1080
Level 4.1
Profile high
Ref Frames 4
Scan Type progressive
Width 1920
Codec DCA
Channels 5.1
Bitrate 1536 kbps
Language English
Audio Channel Layout 5.1(side)
Profile dts
Sampling Rate 48000 Hz
Title DTS 5.1
Codec AC3
Channels 5.1
Bitrate 640 kbps
Language English
Title AC3 5.1
Codec AC3
Channels Stereo
Bitrate 192 kbps
Language Dansk
Audio Channel Layout stereo
Title AC3 5.1
Codec AC3
Channels Stereo
Bitrate 192 kbps
Language Suomi
Title AC3 5.1
Codec AC3
Channels Stereo
Bitrate 192 kbps
Language Norsk
Title AC3 5.1
Codec AC3
Channels Stereo
Bitrate 192 kbps
Language Svenska
Title AC3 5.1
Codec SRT
Language Dansk
Codec SRT
Language Suomi
Codec SRT
Language Norsk
Codec SRT
Language Svenska
Codec SRT
Language Dansk
Format SRT
Codec SRT
Language Suomi
Format SRT
Codec SRT
Language Norsk
Format SRT
Codec SRT
Language Svenska
Format SRT
Set the time (start & end) to run when your server is on.
If users are requesting subtitles and their players cannot process the subtitles as SRT, or are requesting subtitles be burned in (also check your Server settings), the transcoder will run and burn-in those subtitles.
Your sample has an average bitrate of 6.6 Mbps yet you set quality at 4 Mbps. This file will be transcoded when playing if played at these settings
Ok I need to ask. Web setting, does it has something do to when they stream from my server to their TV, or is it only from web streaming from ex. Internet Explorer , Safari etc ?
My server runs from 16pm to aprox 23:45pm everyday except weekend where is from 09am to 00:00pm
If the web streaming quality is set to higher, do I need to change settings, and restart server to take effect?
Yes, The web client, like any client, has desired playback settings. This includes video and audio as well as subtitles.
If the web streaming values are increased, and they do not have subtitles set to always burn-in (unless that’s needed), you will see less transcoder activity
I have changed the settings, still its transcoding. And I know that this user is normally direct playing.
Web settings:
Web
Quality:
Internet Streaming , Video Quality 12Mbps , 1080p ,
Player:
Burn subtitles, automatic
Server:
Ekstras.
Enabled Automatically select audio and subtitle tracks
Prefer audio: English
Subtitled: Alway enabled
Prefer sub: Danish
Does it have something to do with Server- Remote Access - Internet upload speed? I didn’t have that setting before I became plexpass member. What happens if I dont set any info in.?
Seems that some setting is messing up my direct play for Samsung TVs ?
Morphy
New media info:
Video Resolution 720p
Duration 2:13:26
Bitrate 4407 kbps
Width 1280
Height 532
Aspect Ratio 2.35
Container MKV
Video Profile main
Part
Duration 2:13:26
Size 4.11 GB
Container MKV
Video Profile main
Codec H264
Bitrate 4023 kbps
Language English
Bit Depth 8
Color Range tv
Color Space bt709
Height 532
Level 3.1
Profile main
Ref Frames 2
Width 1280
Codec AC3
Channels 5.1
Bitrate 384 kbps
Language English
Codec SRT
Language Dansk
Codec SRT
Format SRT
Another Samsung TV user just direct played this media
So it has to be the first user that have small download speed?
Media
Duration 1:38:56
Bitrate 11500 kbps
Width 1904
Height 816
Aspect Ratio 2.35
Container MKV
Audio Profile dts
Video Profile high
Part
Duration 1:38:56
Size 7.95 GB
Audio Profile dts
Container MKV
Video Profile high
Codec H264
Bitrate 9964 kbps
Bit Depth 8
Frame Rate 24 fps
Height 816
Level 4.1
Profile high
Ref Frames 5
Width 1904
Codec DCA
Channels 5.1
Bitrate 1536 kbps
Language English
Profile dts
Title DTS
Codec SRT
Language Dansk
Title DANSK
Codec SRT
Format SRT
Thanks for that. Browsers don’t accept DTS audio and it’s very likely, unless they have a sound bar, the TV will accept more than 2-channel stero as well. . The transcoder must run to convert the audio to 2-channel stereo
