Tuners will record TV but live TV playback stops working
My tuner card Win TV Quad HD
Linux Setup
The scheduled recorded shows record, but I cannot view TV on any device or browser.
Playback Error
Unable to tune channel (Timed out)
Oct 09, 2017 10:42:34.666 [0x7faefab5a700] INFO - Plex Tuner Service v1.0.0.0 - unknown PC unknown - build:
Oct 09, 2017 10:42:34.666 [0x7faefab5a700] INFO - Linux version: 4.9.0-0.bpo.3-amd64 (#1 SMP Debian 4.9.30-2+deb9u5~bpo8+1 (2017-09-28)), language: en-US
Oct 09, 2017 10:42:34.666 [0x7faefab5a700] INFO - Processor Intel® Xeon® CPU E5-2660 v2 @ 2.20GHz
Oct 09, 2017 10:47:07.574 [0x7faeca7fc700] DEBUG - * DTV_STAT_SIGNAL_STRENGTH: 1, -55000, 18446744073709496616, 0
Oct 09, 2017 10:47:07.577 [0x7faeca7fc700] DEBUG - * strength: 65535
Oct 09, 2017 10:47:07.577 [0x7faeca7fc700] DEBUG - * DTV_STAT_CNR has failed for tuner 0, frontend 0
Oct 09, 2017 10:47:07.579 [0x7faeca7fc700] DEBUG - * quality: 300
Oct 09, 2017 10:56:23.974 [0x7faec9ffb700] INFO - * Starting tuner 0, frontend 0
Oct 09, 2017 10:56:24.053 [0x7faec9ffb700] INFO - * tuner 0, frontend 0 was opened successfully
Oct 09, 2017 10:56:24.053 [0x7faec9ffb700] INFO - * detected tuner ids: vendor (14f1), product (8880)
Oct 09, 2017 10:56:24.053 [0x7faec9ffb700] INFO - * No ca0 node is present for tuner 0
Oct 09, 2017 10:56:24.053 [0x7faec9ffb700] INFO - * CTVSStreamSource::TuneTransponder. Transponder tuning request: diseqc 0, freq 48, modulation 0, polarization 0, symbol rate 0, LOF 0, LNB selection signal 0, FEC 0
Oct 09, 2017 10:56:24.054 [0x7faec9ffb700] INFO - * Tuning request. 48, 0, 0, 0, 0, 0, 0
Oct 09, 2017 10:56:24.064 [0x7faec9ffb700] WARN - [W] CV4lTunersStreamSrc::Start. pthread_setschedparam failed 1
Oct 09, 2017 10:56:24.064 [0x7faecb7fe700] INFO - * Starting streaming thread for tuner 0, frontend 0
Oct 09, 2017 10:56:24.065 [0x7faecb7fe700] INFO - * tuner 0, demux 0. adding PID 20
Oct 09, 2017 10:56:24.698 [0x7faec9ffb700] DEBUG - * DTV_STAT_SIGNAL_STRENGTH: 1, -48000, 18446744073709503616, 0
Oct 09, 2017 10:56:24.701 [0x7faec9ffb700] DEBUG - * strength: 65535
Oct 09, 2017 10:56:24.701 [0x7faec9ffb700] DEBUG - * DTV_STAT_CNR has failed for tuner 0, frontend 0
Oct 09, 2017 10:56:24.703 [0x7faec9ffb700] DEBUG - * quality: 298
Oct 09, 2017 11:00:00.615 [0x7faecbfff700] WARN - [W] CV4lTunersStreamSrc::Start. pthread_setschedparam failed 1
I have a very similar issue. Did you ever get a solution?
I can record shows when they start, but I get this error whenever I try to schedule a record in advance. The error shows “There was not enough free disk space to start the recording”, which is not correct- as I have plenty of disk space. My logs are similar to yours…
Apr 18, 2019 21:42:41.540 [0x7fcca5ffb700] INFO - [I] tuner 0, demux 0. adding PID 97
Apr 18, 2019 21:42:41.541 [0x7fcca5ffb700] INFO - [I] tuner 0, demux 0. adding PID 100
Apr 18, 2019 21:42:41.549 [0x7fcca5ffb700] INFO - [I] tuner 0, demux 0. adding PID 101
Apr 18, 2019 21:42:41.557 [0x7fcca5ffb700] INFO - [I] tuner 0, demux 0. adding PID 102
Apr 18, 2019 21:42:41.565 [0x7fcca5ffb700] INFO - [I] tuner 0, demux 0. adding PID 16
Apr 18, 2019 21:42:41.573 [0x7fcca5ffb700] INFO - [I] tuner 0, demux 0. adding PID 17
Apr 18, 2019 21:42:41.581 [0x7fcca5ffb700] INFO - [I] tuner 0, demux 0. adding PID 18
Apr 18, 2019 21:42:41.589 [0x7fcca57fa700] INFO - [I] tvs_program_streamer::tuning_thread. Finished tuning thread for program triplet://0:2187:6
Apr 18, 2019 21:42:41.741 [0x7fcca6ffd700] INFO - [I] CTSStreamWaiter::GetPidToCheck. PID to check 97
Apr 18, 2019 21:42:41.741 [0x7fcca6ffd700] INFO - [I] CTSStreamWaiter::GetVideoPid. Video PID 97
Apr 18, 2019 21:42:41.773 [0x7fcca6ffd700] INFO - [I] CTSStreamWaiter::ProcessStream. Found first not encrypted packet. Start streaming
Apr 18, 2019 21:42:42.638 [0x7fccb77fe700] INFO - [I] web_service_t::process_device_status
Apr 18, 2019 21:42:42.639 [0x7fccb77fe700] INFO - [I] v4l::DeviceGetList_impl. getting v4l device list
Apr 18, 2019 21:42:42.639 [0x7fccb77fe700] INFO - [I] v4l::DeviceGetList_impl. Successfully opened frontend /dev/dvb/adapter0/frontend0
Apr 18, 2019 21:42:42.789 [0x7fcca6ffd700] DEBUG - [I] DTV_STAT_SIGNAL_STRENGTH: 1, -43000, 18446744073709508616, 1
Apr 18, 2019 21:42:42.789 [0x7fcca6ffd700] DEBUG - [I] DTV_STAT_CNR has failed for tuner 0, frontend 0
Apr 18, 2019 21:42:42.792 [0x7fcca6ffd700] DEBUG - [I] quality: 320
Apr 18, 2019 21:42:45.796 [0x7fccbd5f7700] INFO - [I] web_service_t::process_device_status
Apr 18, 2019 21:42:45.796 [0x7fccbd5f7700] INFO - [I] v4l::DeviceGetList_impl. getting v4l device list
Apr 18, 2019 21:42:45.796 [0x7fccbd5f7700] INFO - [I] v4l::DeviceGetList_impl. Successfully opened frontend /dev/dvb/adapter0/frontend0
Apr 18, 2019 21:42:45.958 [0x7fcca6ffd700] DEBUG - [I] DTV_STAT_SIGNAL_STRENGTH: 1, -43000, 18446744073709508616, 1
Apr 18, 2019 21:42:45.958 [0x7fcca6ffd700] DEBUG - [I] DTV_STAT_CNR has failed for tuner 0, frontend 0
Apr 18, 2019 21:42:45.962 [0x7fcca6ffd700] DEBUG - [I] quality: 327
