and use it for TVShows you get fix your problem and get a better metadata for your TVShows.
In my point of view now TheMovieDB is better than TheTVDB.com
@RicardoVelaC agreed, overall TheMovieDB is better but there is one major drawback related to how plex gets casts from TheMovieDB over TheTVDB (see below). If @TheEsp can live with that then switching to that provider is a good option.
Not really – if you want to change your TV library to use TMDB then under Settings -> Manage -> Libraries select your TV Library. Select advanced and change the agent to The Movie Database. Scan and refresh metadata should then switch for you.
