TV Episode is getting recorded twice
If you have a look here
Select Global Non Line up at the bottom, will give shows with problems
Thank you. Very useful.
I’m just getting started with Plex and am seeing this same repeat problem. The two examples I have seen so far is a program on PBS that is repeating several times in one night and when I select the first viewing to record it marks all of the repeats also. I went in the advance section and marked it for only the first time and it still marked all.
Similar problem in a show that is on more than one channel, I marked the show on the channel I wanted to record and went into advance and selected the channel I want record and it still sets up both channels.
I’m using 1.16.6.1559-a71394a45 which I think is the latest.
The PBS show that marked 3 copies (2 being marked repeat) was tonight and even though 3 were marked to be recorded only the first was recorded, not sure what would have happened if I had other things scheduled for the other two time slots. Maybe the only bug is not updating the broadcast listings.
