Recently I have been noticing issues with TV metadata not loading sometimes, and other times it will take a very long time to populate.
Every movie I add, gathers and populates metadata in ~10-20 seconds. TV episodes will sometimes populate just as quick, but it’s hit or miss. Yesterday I added a few episodes that have not populated the metadata in Plex, but it seems that it completed downloading the metadata.
I have removed the cache dir’s and restarted the docker. Tried re-downloading metadata. Download finishes, nothing populates in Plex. Also per the post I came across pertaining to the cache, the entire directory under config is chown’d by the correct user and the docker is set to use that PUID/PGID.
I also tried check marking The Movie Database in the TheTVDB agent to give it another source to gather from. No luck.
I added 7 total episodes yesterday. Four populated their metadata. Four of seven of the episodes are for the same show. Only one of those four episodes populated its metadata.
Most posts I have read go on to ask about the naming scheme. All of my TV folders are named as such: Series/Series - Season X/Series - SxEE - Episode Name.WEBDL-QUALITY.mkv
I have even attempted removing it from its directory, renaming it without the WEBDL-QUALITY and re-adding it. Feeling stumped.
Sorry forgot to attach this. Restarted the docker, removed files and re-added them, let it sit for a little while to attempt to populate. Downloaded logs and attached.
Well… now that I attached the logs. They finally updated metadata. I added those to the Library yesterday though and nothing had changed before I started posted. This has been happening a lot lately though where it takes a VERY long time for tv episodes to update. It’s frustrating! Lol :#
Picking an example of how it is not per the guidelines
You have
Arrow/
Arrow - Season 6/
Arrow - 6x16 - The Thanatos Guild.WEBDL-1080p.en.srt
Arrow - 6x16 - The Thanatos Guild.WEBDL-1080p.mkv
Following the guidelines / naming standards, it should be
Arrow/
Season 6/
Arrow - s6e16 - The Thanatos Guild.WEBDL-1080p.en.srt
Arrow - s6e16 - The Thanatos Guild.WEBDL-1080p.mkv
Please follow the guidelines and if you have a problem when you do follow the guidelines then raise it here with debug logs and details of what went wrong
