Server Version#: 1.42.2.10156
Player Version#: 1.110.0.351-4e48eb83
Hi, for whatever reason for the past 3 weeks or so I’m noticing that while using the Plex Series Agent metadata for my tv show library it never adds the metadata for each episode. For example I have Alice in Borderland season 3 episodes 1-6. If I were to edit E01 all fields under General is empty except for Originally Available which have 1969-12-31. The Metadata for the overall show seems fine.
If I were to click on any of those episodes and Refresh Metadata it would correct itself and populate each episode with metadata. I do not have this issue when I switch the library to use the TheTVDB as the agent.
Any help would be appreciated, hopefully I’ve explained this properly if you have questions please feel free to ask.
bumping this so it’s not lost in the void.
From what I see the Series will match perfectly fine and metadata will populate for the series but for each individual episode metadata is not populating automatically unless I manually refresh the metadata for it.
I have attempted to recreate your problem. I created a directory “Alice in Borderland (2020)” in my tv show Library. There are two shows with the same name on TMDB, one from 2014 & one from 2020. I chose the 2020 series. I copied a dummy mp4 file to S03E0{1..6}.mp4
Seems to be getting correctly identified and I am getting the show metadata. I.e., release dates, episode synopsis, etc.
I suspect you are missing the year, 2020, from your series directory. The 2014 series only has one season of 3 episodes on TMDB
@napolij given the post I suspect its either a DNS or database corruption issue. Given it affects more than 1 series. Which is why I requested a copy of their server logs.
I use Sonarr and Radarr for my content and this naming scheme helps with importing back into sonarr/radarr in the event my DB becomes corrupted Recommended naming scheme - TRaSH Guides (sorry if external links are not allowed). I confirmed with them and other users in the community if they were experiencing this issue that I experience
For those of you with media renaming tools, it’s trivial to transfer this rule into them. I use FileBot. Both FileBot and Sonarr create the exact same name.
I just created a folder with the name you provided and added a file with the filename you provided. Plex picked it right up. As dbirch mentioned, there is probably something else going on aside from the naming.
So you enabled verbose logging so the logs are useless. Oct 02, 2025 16:04:22.293 [139877420395320] VERBOSE Please reset to debug, and perform a plex dance on media that isnt pulling metadata, and then upload a fresh set of logs.
