My TV Media library is not displaying all seasons. I can see items from the missing season under recently added, and I can get into the season from there. I cannot get into the season under “All Shows” though. This is happening across multiple TV shows for items that I’ve added recently.
OK so I found a suggestion on Reddit that worked:
Remove the files from the folder in Windows Explorer.
Scan/update the library.
Put the files back.
Scan/update the library again.
Problem solved.
I only wish Plex would find and fix this problem on its own, who has time to babysit it?
Sorry, I fail to see the issue in your screen shot.
Apparently you are already on the preplay screen of season 9.
And you are missing the link in the drop-down menu to get to season 9 …
What is the point of having that link, if you are already there?
The point of the screenshot was to show 2 things:
I had season 9 in my media library
There was no link to season 9 within Bob’s Burgers
When I switched to another season, and wanted to switch back to season 9, I couldn’t. There was no link. When I went into Bob’s Burgers there were only seasons 1-8 shown.
But, Plex knew season 9 was there because it was showing the new episodes under recently added on the home screen. So, this was clearly a bug. This is what it looks like now that I removed and re-added season 9:
