TV Show not found when searching on TVDB
Hi. This is my first post so apologies if this is an obvious question.
I have episodes of WWE NXT and I have previously matched this up against TVDB as the agent with no problems. I have re-organised my file location and Plex filing structure but the only issue is that when I search for WWE NXT now on TVDB, it cannot find the show. The show is still on the TVDB website (series ID 144541) but the only hit on the results is for WWE NXT UK which is obviously a different programme. I have tried different variations of the name with no joy. To top this off, TMDB finds WWE NXT but their episode info is out of date, contains errors and I will have to rename my files. Does anyone have any reason why this is happening, any ideas on how to fix this and I dont want to have to rename around 450 files. Any help will be appreciated.
Regards
Alex
Yep, there are matching issues with the TVDB.
try a fix match on the show and enter the ID number in the title box, that should hopefully fix it.
For more info on how have a look here:
Thank you very much for the quick response. This worked perfectly and my files now all have the correct metadata.
Much appreciated.
