I’ve been working on this issue for a few weeks now and searching online and the Plex forums for the answer.
I had a hard drive failure where I had to backup all my TV shows, redo my RAID, and then import them back. This took weeks to do because of the size of the library. During this time my library must have auto updated, even though I had auto update off. I tried restoring to a previous library but the previous versions had issues with restoring the metadata, as well. On other forum and thread suggestions I’ve renamed the directory and did a scan on the empty library, cleaned the bundles, emptied trash and optimized, named the directory back, and then scanned. This is for all shows.
Issue comes back. Main poster appears, episodes are named correctly with all their metadata. The season posters do not appear.
I’ve verified my naming scheme matches completely with the databases. I’ve tried using TheTVDB and TheMovieDB, as well as unmatching and re-matching and Fixing incorrect match for the shows. I’ve trashed the library completely, and started fresh. Uninstalled PMS, re-installed. I’m using the latest version, however, I’ve tried previous versions, and all provides the same issue. I tried deleting a few other plug-in folders and metadata folders. Either they repopulate and the issue persists, or I have another problem and I have to paste back the original configuration that I saved for such instances.
I’ve even added new shows and the problem is still appearing. I’ve looked at previous threads from a year ago stating a similar issue, but all the threads state that a version update had fixed the issue, and some had workarounds that I tried using, as stated above. Rebooting system has had no effect and the log files show no problems, as far as I can tell.
Any other suggestions would be greatly appreciated. Currently running Windows 7 Ult x64. I’m working on transferring to a new system using Server 2012 R2, but not planning to attempt until the issue is resolved. If necessary, I may migrate if that would help the issue, but I’m not thinking that will fix the issue as the process seems unrelated.
