TV show seasons lost
Server Version#: 1.16.3.1402
Player Version#: N/A
On previous TV shows, when you select the show, it displays seasons and you select the seasons to see the episodes. Now, it shows all the episodes and you need to select each one to see what season it’s a part of. Was this intentional (and if so, why) or something you’re working out after changing the media information source?
Some context please? Screenshots perhaps?
You’ve not given much to go on. Can you elaborate further?
Sure. The first shot is the list of all the shows I have recordings of:
When I select 2 Broke Girls, the episodes are separated by seasons.
When I select Boston Legal, all 40 episodes (from 3 different seasons) are bunched together instead of separated.
Thanks for having a look!
Paul
Edit library, and select advanced
Make sure Seasons is not set to hide
If the visibility of seasons varies ‘by tv show’, you have to edit the properties of the show itself, and not the global library setting. (again, on the ‘Advanced’ tab)
I recommend to set the global library setting to ‘Hide for single-season series’
and then, in the properties of each tv show, ‘Use library default’.
It’s the easiest.
I set it back to “Library Default”. This is not a setting I’ve ever changed. “Hide” must be the new default. Thanks for the assist, people.
Paul
I don’t think so. Are only newly added tv shows affected, or also old ones?
Just the two latest ones. They were both started on July 8. It’s a change for sure.
