TV Shows are not showing season view
Server Version#: 4.51.3
Player Version#: N/A
Hi, since the latest upgrade on the server, honestly I’m not sure when is started the Season view on TV shows is missing?
When I look into TV Shows I see the show and all the episodes in the same view. I don’t have the possibility to see what’s in the different seasons. Every episode does have season information and episode information in it.
I have not changed any naming och something like that… it has always worked with the same folder structure/naming previously.
I have looked through settings and can’t find anything.
Thanks!!
Does this has to be done per show? Isn’t there any global way to change the default setting?
It’s a central option in the advanced settings of each library. You can override that default per show.
Yepp found it… thanks for the quick help!!!
