Server Version#: 4.77.3
Hi, I recently noticed the Metadata for Young Rock was wrong. I then go to switch the Agent from the Plex TV Series to TheTVDB one but it keeps switching back. TheTVBD one for Young Rock is correct, so can you please fix it for the Plex TV Series one too? You need the Christmas Special one in Season 00 so it’s Specials (like TheTVBD one) and then Season 2 match TheTVBD one also. But the main issue is it seems it it keeps switching from TheTVBD one after I update it to that. Really getting annoying.
Okay, what happens is I get an Upgrade Libraries update notice on my TV Shows Library. If I click that, it then switches to Plex TV Series and that’s where the screw up for Young Rock happens. Please fix Young Rock so I can update the Library properly! This happening to anyone else?
Familiarize yourself with the preference “Episode ordering”
Episode Ordering : How episodes are named on disk. If your naming follows The MovieDB or TheTVDB choose that here.
This must be going over my head. It works perfectly how I have them named using TheTVBD’s structure. How should I have the episodes named? Also, Sonarr follows TheTVBD’s structure too.
Found Naming and Organizing Your TV Show Files and changed my Season 0 folder to Specials and think that did the trick (*fingers crossed). Hope this helps if someone else has a similar issue with a show.
