Server Version#: 1.20.2.3343 Player Version#: NA
My prod server… Have folder with 4 seasons of Austin City Limits, one season of Kevin Belton. Both only show epsodes, and not season!!
On test server, same version, it shows up correctly. Only difference is plex pass on prod, and not test.
Any thoughts?
On the ‘prod’ server, go to the Library Advanced settings for that library and see what the ‘Seasons’ pop-up menu is set to. Sounds like it should be set to ‘Show’ to show the seasons. It might be set to ‘Hide’ right now.
That’s where I’d start looking anyway! Good luck.
thanks… but both prod and test are set to Show.
That setting is also available on individual shows, if you edit the show itself. Worth checking there too.
OK… individual settings was issue… I did not know about that.
How in the heck did that get changed.?
