Episodes not added into Seasons
Server Version#: Windows Server 1.25.3.5409
Player Version#: LG 5.30.1
I noticed for many TV series, Plex Server will not group episodes into Seasons, will just show episode count for each series, and then when you click on the series the episodes are just listed instead of seeing the season folder.
I thought this was because for these specific series I had episodes from only 1 season, but when I check my other Plex Server, it also has single season series and for all these the seasons are shown correctly. Both Plex Servers are same version.
Anyone know why this is happening and how to fix it? I tried moving the episodes out of Plex and back in, same results, even tried to add them to folder with season name, still nothing.
There is a library specific option to hide seasons and show episodes instead if there is just one season when you go to the show. See if that setting is what is triggering for you.
That fixed it, thanks for the information. Not sure how this was set, but once I switched setting, all series now show seasons.
Thanks again.
