Tv Shows Metadata and Scanner - Somes series not coming up
@Peter_W said:
Do also note that tvdb, the actual external site where Plex gets all data from, currently has a bug on their hand too. That bug was obscured by Plex own bugs before and is now currently being handled by tvdb. The geist of it was, as I recall, that tvdb prev reported an actual error to Plex when the metadata was empty for your language (it was here Plex bug lie, we didn’t fallback correctly), now tvdb just reports “empty” which breaks Plex logic. This will be handled soon. In the meantime, while thats being handled I’m sure that the dev’s would like to see your logs after a failed attempt to download metadata.
Hi @Peter_W
Version 1.1.3.2700 still “reports “empty” which breaks Plex logic.”
THX for the info!
Braz.
It should not.
Try deleting the http cache of the TheTVDB agent.
Then try again.
Make sure your files follow the Plex naming convention for tv shows.
Make sure that you use your native language’s title for the show in its file and folder names.
(Some shows have different titles, depending in their metadata language. TheTVDB website will only return results if your files are named in the language of the metadata you are requesting.)
@OttoKerner said:
It should not.
Then try again.
I Already try…with no success :frowning: Plex Inc is working together with TVDB to fix it.
