Thanks for the reply. Using mp3tag I saw that it had some incorrect metadata and I corrected that.
I verified the library path and it is set to E:\Multimedia\TV Shows I have several hundred other shows in that library so I think that is correct.
I did poke around in the Plex Media Scanner log file and I found the following entries. It looks like it thinks the program is already there? How can I look at what it thinks is the program?
Mar 16, 2020 12:58:08.436 [9608] DEBUG - Scanner: Processing directory E:\Multimedia\TV Shows\10 That Changed America (parent: yes)
Mar 16, 2020 12:58:08.439 [9608] DEBUG - Skipping over directory ‘10 That Changed America’, as nothing has changed; removing 0 media items from map.
Mar 16, 2020 12:58:08.439 [8608] DEBUG - HTTP requesting GET http://127.0.0.1:32400/:/metadata/updateProgressMessage?message=Scanning%2010%20That%20Changed%20America
Mar 16, 2020 12:58:08.442 [9608] DEBUG - Scanner: Processing directory E:\Multimedia\TV Shows\10 That Changed America\Season 01 (parent: yes)
Mar 16, 2020 12:58:08.445 [9608] DEBUG - File ‘E:\Multimedia\TV Shows\10 That Changed America\Season 01\10 That Changed America - s01e03.mp4’ changed write time, can’t skip.
Mar 16, 2020 12:58:08.451 [8608] DEBUG - HTTP 200 response from GET http://127.0.0.1:32400/:/metadata/updateProgressMessage?message=Scanning%2010%20That%20Changed%20America
Mar 16, 2020 12:58:09.199 [9608] DEBUG - Looking for path match for [E:\Multimedia\TV Shows\10 That Changed America\Season 01\10 That Changed America - s01e03.mp4]
Mar 16, 2020 12:58:09.201 [9608] DEBUG - Path matched, we’re reusing media item 107079
Mar 16, 2020 12:58:09.202 [9608] DEBUG - Updating media item 107079, size=210980888, metadata_item_id=102045
Mar 16, 2020 12:58:09.203 [9608] DEBUG - Updating part with ID=109282 [E:\Multimedia\TV Shows\10 That Changed America\Season 01\10 That Changed America - s01e03.mp4]
Mar 16, 2020 12:58:09.203 [9608] DEBUG - Noting item as needing media analysis, scanning=0, streams=0, missing channels=0, streamability=0, size=0, time=1.
Mar 16, 2020 12:58:09.203 [9608] DEBUG - Turbo analysis on modified item 107079 [E:\Multimedia\TV Shows\10 That Changed America\Season 01\10 That Changed America - s01e03.mp4]
Mar 16, 2020 12:58:09.204 [9608] DEBUG - Updating media item 107079, size=210980888, metadata_item_id=102045
Mar 16, 2020 12:58:09.205 [9608] DEBUG - Updating part with ID=109282 [E:\Multimedia\TV Shows\10 That Changed America\Season 01\10 That Changed America - s01e03.mp4]
Mar 16, 2020 12:58:09.206 [9608] DEBUG - HTTP requesting PUT http://127.0.0.1:32400/activities/a6762513-7ce1-469e-b98d-a1200e15db5e?percentComplete=%2B0.163398698&subtitle=Season%2001
Mar 16, 2020 12:58:09.209 [9608] DEBUG - HTTP 200 response from PUT http://127.0.0.1:32400/activities/a6762513-7ce1-469e-b98d-a1200e15db5e?percentComplete=%2B0.163398698&subtitle=Season%2001
Mar 16, 2020 12:58:09.209 [9608] DEBUG - Scanner: Processing directory E:\Multimedia\TV Shows\10 That Changed America\Season 02 (parent: yes)
Mar 16, 2020 12:58:09.215 [9608] DEBUG - Skipping over directory ‘10 That Changed America\Season 02’, as nothing has changed; removing 1 media items from map.
Mar 16, 2020 12:58:09.216 [9608] DEBUG - HTTP requesting PUT http://127.0.0.1:32400/activities/a6762513-7ce1-469e-b98d-a1200e15db5e?percentComplete=%2B0.163398698&subtitle=Season%2002
Mar 16, 2020 12:58:09.217 [8608] DEBUG - HTTP requesting GET http://127.0.0.1:32400/:/metadata/updateProgressMessage?message=Scanning%2010%20That%20Changed%20America\Season%2002
Mar 16, 2020 12:58:09.219 [9608] DEBUG - HTTP 200 response from PUT http://127.0.0.1:32400/activities/a6762513-7ce1-469e-b98d-a1200e15db5e?percentComplete=%2B0.163398698&subtitle=Season%2002
