You should not enter any show folders if the scanning process is not complete.
The files in your ‘iZombie’ folder look perfectly regular and a properly executed Plex Dance should make them available.
I found this:
Feb 29, 2016 16:37:01 [0xedbffb70] ERROR - [Notify] Failed to add watch for /volume2/Data_1/Series/Vikings (13: Permission denied)
Have you checked permissions on these folder(s)? The Syno FAQ (Q5) mentions users Plex and admin
I am no Synology expert, better refer to the pro’s in the Synology subforum on how to change permissions.
What are these metadata subfolders?
/volume2/Data_1/Series/The Walking Dead/Season 01/metadata
They don’t belong to Plex. Your Series library is full of them. I don’t know whether they interfere with the Plex scanners, but it is something to keep an eye on or to get rid of as a precaution.
Your Plex database needs an optimization
Feb 29, 2016 16:37:45 [0xef335b70] WARN - SLOW QUERY: It took 220.000000 ms to retrieve 44 items.
Feb 29, 2016 16:37:45 [0xef335b70] DEBUG - It took 180.000000 ms to retrieve 49 items.
Feb 29, 2016 16:37:45 [0xef335b70] WARN - SLOW QUERY: It took 310.000000 ms to retrieve 50 items.
You have loads of non-ascii characters in the file and folder names of your music library. You may have trouble recognising local/embedded cover art or sidecar song lyrics.
/volume1/music/D.��.M.A
/volume1/music/D.\xce\x94.M.A/D.\xce\x94.M.A - Uma Quest\xc3\xa3o De Princ\xc3\xadpio (2014)
/volume1/music/Carl\xc3\xa3o/Carl\xc3\xa3o - Quarenta [2015]
/volume1/music/Da Weasel/07 Amor, Esc\xc3\xa1rnio e Maldizer [CD] 2007
But that is just an aside remark.
in the localmedia.log there is this:
2016-02-29 02:34:33,089 (-b057490) : DEBUG (model:32) - Loading model with GUID com.plexapp.agents.thetvdb://81797/17/62?lang=en
2016-02-29 02:34:33,091 (-b057490) : ERROR (model:205) - Cannot read model from /volume1/Plex/Library/Application Support/Plex Media Server/Metadata/TV Shows/9/69570a64254e574295dfe1dfdf2921f33f3ee43.bundle/Contents/com.plexapp.agents.thetvdb
2016-02-29 02:34:33,130 (-b057490) : DEBUG (model:32) - Loading model with GUID com.plexapp.agents.thetvdb://81797/17/62?lang=en
2016-02-29 02:34:33,131 (-b057490) : ERROR (model:205) - Cannot read model from /volume1/Plex/Library/Application Support/Plex Media Server/Metadata/TV Shows/9/69570a64254e574295dfe1dfdf2921f33f3ee43.bundle/Contents/com.plexapp.agents.localmedia
but I am unsure what causes this. It repeats for almost every show in your library.
it appears TheTVDB still returns an invalid answer for ‘The Flash’
2016-02-29 16:11:04,850 (-bfb8490) : ERROR (networking:217) - Error opening URL 'http://thetvdb.plexapp.com/api/D4DDDAEFAD083E6F/series/276820/en.xml'
or you did not clear the agent caches, yet
The system log shows some difficulties Plex accessing itself
2016-02-29 16:36:54,736 (-da4e490) : ERROR (networking:217) - Error opening URL 'http://192.168.1.56:32400/library/sections'
2016-02-29 16:36:54,737 (-da4e490) : ERROR (peerservice:81) - Failed to fetch data from http://192.168.1.56:32400/library/sections: ()
I remember seeing this a few days ago in another log. I think a fix has been scheduled for the next major release.
Now gotta go for while.
I relayed the log files to @MovieFan.Plex for reference
