I’m having the same problem - can’t get any TV shows to match. Here’s a snapshot from my logs:
2020-12-05 08:31:25,937 (7fcaa9ffb700) : INFO (__init__:369) - Searching for exact match with: The+Drew+Carey+Show (lang: en)
2020-12-05 08:31:25,937 (7fcaa9ffb700) : DEBUG (networking:143) - Requesting 'https://tvdb2.plex.tv/login'
2020-12-05 08:31:30,102 (7fcaa8ff9700) : INFO (__init__:369) - Searching for exact match with: The+Drew+Carey+Show (lang: en)
2020-12-05 08:31:30,103 (7fcaa8ff9700) : DEBUG (networking:143) - Requesting 'https://tvdb2.plex.tv/login'
2020-12-05 08:31:35,957 (7fcaa9ffb700) : INFO (__init__:140) - JWT Error: (<urlopen error [Errno -2] Name or service not known>) -
2020-12-05 08:31:35,959 (7fcaa9ffb700) : DEBUG (networking:143) - Requesting 'https://tvdb2.plex.tv/search/series?name=The+Drew+Carey+Show'
2020-12-05 08:31:40,123 (7fcaa8ff9700) : INFO (__init__:140) - JWT Error: (<urlopen error [Errno -2] Name or service not known>) -
2020-12-05 08:31:40,124 (7fcaa8ff9700) : DEBUG (networking:143) - Requesting 'https://tvdb2.plex.tv/search/series?name=The+Drew+Carey+Show'
2020-12-05 08:31:45,974 (7fcaa9ffb700) : INFO (__init__:175) - Problem with the request:
2020-12-05 08:31:45,976 (7fcaa9ffb700) : INFO (__init__:379) - There was a problem attempting an exact TVDB match in The+Drew+Carey+Show (lang: en)
2020-12-05 08:31:45,978 (7fcaa9ffb700) : DEBUG (runtime:88) - Sending packed state data (107 bytes)
2020-12-05 08:31:45,978 (7fcaa9ffb700) : DEBUG (runtime:924) - Response: [200] str, 320 bytes
2020-12-05 08:31:50,144 (7fcaa8ff9700) : INFO (__init__:175) - Problem with the request:
2020-12-05 08:31:50,145 (7fcaa8ff9700) : INFO (__init__:379) - There was a problem attempting an exact TVDB match in The+Drew+Carey+Show (lang: en)
2020-12-05 08:31:50,147 (7fcaa8ff9700) : DEBUG (runtime:88) - Sending packed state data (107 bytes)
2020-12-05 08:31:50,147 (7fcaa8ff9700) : DEBUG (runtime:924) - Response: [200] str, 320 bytes
2020-12-05 08:32:07,014 (7fcaa8ff9700) : DEBUG (runtime:717) - Handling request GET /:/plugins/com.plexapp.agents.thetvdb/messaging/function/X0FnZW50S2l0OlNlYXJjaA__/Y2VyZWFsMQoxCmxpc3QKMApyMAo_/Y2VyZWFsMQoyCmRpY3QKZGljdAo2CnMyCmVuczQKbGFuZ2IxczYKbWFudWFsYjFzNwpwcmltYX
J5aTAKczcKdmVyc2lvbnIxCnM2Cmt3YXJnc3M3ClRWX1Nob3dzMTAKbWVkaWFfdHlwZTMKbnM0CnllYXJzNQo1NTA1NXMyCmlkczUKNzEzNTVzNApzaG93cjAK
2020-12-05 08:32:07,015 (7fcaa8ff9700) : DEBUG (runtime:49) - Received packed state data (80 bytes)
2020-12-05 08:32:07,017 (7fcaa8ff9700) : DEBUG (runtime:814) - Found route matching /:/plugins/com.plexapp.agents.thetvdb/messaging/function/X0FnZW50S2l0OlNlYXJjaA__/Y2VyZWFsMQoxCmxpc3QKMApyMAo_/Y2VyZWFsMQoyCmRpY3QKZGljdAo2CnMyCmVuczQKbGFuZ2IxczYKbWFudWFsYjFzNwpwcmltYX
2020-12-05 08:32:07,017 (7fcaa8ff9700) : INFO (agentkit:961) - Searching for matches for {'show': '71355', 'id': '55055', 'year': None}
2020-12-05 08:32:07,018 (7fcaa8ff9700) : DEBUG (networking:143) - Requesting 'http://127.0.0.1:32400/library/metadata/55055/tree'
2020-12-05 08:32:07,081 (7fcaa8ff9700) : DEBUG (networking:143) - Requesting 'https://tvdb2.plex.tv/login'
2020-12-05 08:32:17,096 (7fcaa8ff9700) : INFO (__init__:140) - JWT Error: (<urlopen error [Errno -2] Name or service not known>) -
2020-12-05 08:32:17,103 (7fcaa8ff9700) : DEBUG (networking:143) - Requesting 'https://tvdb2.plex.tv/series/71355?lang=en'
2020-12-05 08:32:27,120 (7fcaa8ff9700) : INFO (__init__:175) - Problem with the request:
2020-12-05 08:32:27,122 (7fcaa8ff9700) : INFO (__init__:529) - Couldn't find Series in TVDB XML: object of type 'NoneType' has no len()
2020-12-05 08:32:27,125 (7fcaa8ff9700) : DEBUG (networking:143) - Requesting 'https://meta.plex.tv/tv/guid/53/539a2f221d237f212ee148cd346a95501cc6ed26.xml'
2020-12-05 08:32:37,145 (7fcaa8ff9700) : INFO (__init__:277) - URLError(gaierror(-2, 'Name or service not known'),)
2020-12-05 08:32:37,151 (7fcaa8ff9700) : DEBUG (networking:143) - Requesting 'https://meta.plex.tv/tv/names/en/53/539a2f221d237f212ee148cd346a95501cc6ed26.xml'
2020-12-05 08:32:47,171 (7fcaa8ff9700) : INFO (__init__:369) - Searching for exact match with: 71355 (lang: en)
2020-12-05 08:32:47,172 (7fcaa8ff9700) : DEBUG (networking:143) - Requesting 'https://tvdb2.plex.tv/login'
2020-12-05 08:32:57,188 (7fcaa8ff9700) : INFO (__init__:140) - JWT Error: (<urlopen error [Errno -2] Name or service not known>) -
2020-12-05 08:32:57,191 (7fcaa8ff9700) : DEBUG (networking:143) - Requesting 'https://tvdb2.plex.tv/search/series?name=71355'
2020-12-05 08:33:07,211 (7fcaa8ff9700) : INFO (__init__:175) - Problem with the request:
2020-12-05 08:33:07,212 (7fcaa8ff9700) : INFO (__init__:379) - There was a problem attempting an exact TVDB match in 71355 (lang: en)
2020-12-05 08:33:07,215 (7fcaa8ff9700) : DEBUG (runtime:88) - Sending packed state data (107 bytes)
2020-12-05 08:33:07,215 (7fcaa8ff9700) : DEBUG (runtime:924) - Response: [200] str, 320 bytes
Doesn’t matter if I use the name or the show ID, I can’t get anything to match.
OS: ubuntu 18.04
plex: 1.21.0.3711
Moderator Edit: Added formatting for legibility
