Hi everyone ! I’m a new Plex user, and I’m experiencing troubles with adding TV Shows.
I followed this article for naming : https://support.plex.tv/articles/200220717-local-media-assets-tv-shows/
My file structure looks like this : 16|690x709
I also did the ‘Plex dance’ many times.
However I’m steel totally stuck.
Hope someone can help me !
Best regards !
Romain!
If you can’t even get the library - click more and pin it to the side bar (wild guess) - providing “TV Shows” is a TV Show Library Type and Plex is aimed ONLY at the ‘TV Shows’ folder.
Your file naming is fine - so that’s not the problem (and it usually is - congratulations).
Yep, it all looks normal and proper to me… hmmm
You have triggered a manual scan of said library? A shared library may not automatically detect itself, or the changes therein.
Try Settings/ scroll down that first page a bit and press ‘Reset Customization’ (Save, I guess, would be the next button you press) - you may have to re-pin the Movie Library or you may see everything just show up.
If that doesn’t work - we’ll call in the paramedics. I feel it’s something simple we’re (I am) missing.
Nope that doesn’t work. I’ve also tried to delete, re-create the library, it’s still does’nt work.
Also, I don’t know if it can help to identify the problem, the scan is performed in less than 2s each time, like if there are no files in the directory
Is it perhaps a permissions issue? Can you make sure user “plex” has at least read and execute permissions to the directories/files you’re adding to your library?
Ok, thx @pshanew !!! It was a permission problem as you said, I did a chmod 775 -r on the Season 01 folder of Chernobyl, and the magic operred !!! I’m so happy ! I was stuck for two days !
Ok, thx @JuiceWSA, I just did it, so for resume, if anyone else is stuck with a problem like this, try to make a chmod 775 -R on the directory the library is pointing on
