TV Shows not showing up after being added as a library
Hello,
I am sure this question has been answered every possible way, but for some reason I cannot find my solution :frowning: hoping I can find it here.
I am trying to enable TV Shows in my plex library. Here are the steps I have taken.
Manage >> Libraries >> Add Library TV Shows → Point to folder:
/plex/TV Shows/
Within the TV Shows directory, I have one episode of supernatural I am using to try and set this up. I have that named as follows:
plex/TV Shows/Supernatural/Season 7/Supernatural.S07E02.Hello.Cruel.World.1080p.BluRay.mkv
By doing these steps I do see a new TV Shows category appear in my list on the left within the plex interface, but when I click scan ‘Scan library files’ it returns:
“TV Shows” is empty
I have seemingly the exact same configuration setup for /plex/Movies and that seems to be working perfectly.
Any thoughts? And sorry for creating a thread which most likely has already been answered.
For the fun of it… try to drop the technical blah blah from your file names – just to rule out it’s getting in the way:
plex
  TV Shows
    Supernatural
      Season 07
        Supernatural - s07e02 - Hello Cruel World.mkv
        OR
        Supernatural - s07e02 - Hello Cruel World [1080p BluRay].mkv
On what platform are you running your server?
Have you verified the server has access to those files (permissions)?
All those Periods in the file name… Oh dear.
Thank you for the quick reply.
I did a quick rename:
/plex/TV Shows/Supernatural/Season 7/Supernatural - s07e02 - Hello Cruel World.mkv
But that did not seem to do the trick.
Your comment about permissions has me wondering. I am running it on a QNAP, and looking at the underlying file permissions on the CLI it shows the exact same as it does in the movies directory RW - RW - RW, and the folders being RWXRWXRWX. Is there some other place I need to verify permissions are set? Perhaps in the plex GUI somewhere?
Was just trying something I saw on another forum. I do not use periods in my naming conventions typically :slight_smile:
Remove that corrected file and do the Plex dance, return the file to storage device and scan.
Reference to correct Naming.
Hi SE56,
Thanks, I tried the plex dance on the Supernatural title above, but it did not seem to do the trick. Do you know of any other tips I could try here?
The periods are fine. As far as I can tell, Plex doesn’t use periods as separators to break up the episode-matching logic.
I think it shouldn’t matter, but try putting “Season 07” with a leading zero. It’s standard advice, and I see you haven’t done that yet. From what I know of the Plex logic, that doesn’t matter for how it finds files, but it wouldn’t hurt to try…
One last question from a Linux newbie… But you did verify that the PLEX user has those permissions, not yourself, in case it runs under a different user?
Yeah, Try adding the Following {tvdb-78901} in folder name.
Supernatural (2005) {tvdb-78901}
Thank you everyone for your assistance, the issue for me came down to the spaces in TV Shows. I could not figure out the correct syntax to add the spaces to the name so I simply renamed my folder TV Shows to “TV”. Reran the library import and now things are working.
Thank you for all of your assistance, I am surprised how quickly I was helped.
That’s a bit odd. What OS is your Media Server running on?
Hi BigWheel,
I am running it on a QNAP QTS 5.1.0
On the QNAP
pwd
/share/CACHEDEV1_DATA/plex/TV Shows
ls /share/CACHEDEV1_DATA/plex/TV\ Shows/
Supernatural/
For the library location I tried adding:
and
Neither one seemed to work. Renaming ‘TV Shows’ to ‘TV’ and adding this path:
Did work
It must be with how I am trying to add it with the space.
