TVDB not Working?
Hi All!
This issue starts a few days ago. If i add any episode to my library i can´t get any info from tvdb. Need to change the agent to TMDB but this one is not so complete as TVDB. Is there any problem with TVDB?
THX,
Braz.
TVDB changed their API thus metadata fetching is currently broken. TVDB tried this earlier in 2019 and had to rollback their API update. Not sure what the solution is or the workaround. I feel your pain, as I too have some new TV episodes without metadata. :face_with_symbols_over_mouth::face_with_symbols_over_mouth::face_with_symbols_over_mouth:
CC: @spinningbull @ChuckPa
Thank you for your fast reply! @Achilles . I just notice that i can´t have the info with filebot… so it´s a TVDB side that is not working…Let´s hope that this can be solve soon. Meanwile i will keep using TMDB as an agent.
THX,
Braz.
https://forums.thetvdb.com/viewtopic.php?f=3&t=60048
