Server Version#: 1.20.1.3252 (Debian Linux) and 1.20.2.3370 (Mac)
I have three servers running on my LAN, one on a Mac and two on Linux boxes (OMV on 4.19.118-2 and proli2 on 4.9.88-1)
They are all configured the same way:
- Enable IP6
- Secure preferred
- GDM enabled
- Relay enabled
For remote access I am forwarding external ports 32401, 32402, 32403 to port 32400 on their respective local IPs.
However when I connect to them, whether I do it locally by 192.168.1.x:32400/web or app.plex.tv, only one of the Linux boxes (proli2) connects securely. The other two (OMV and the Mac) require an insecure connection and do not respond to https.
$ curl https://127.0.0.1:32400 -v -k
* Rebuilt URL to: https://127.0.0.1:32400/
* Trying 127.0.0.1...
* TCP_NODELAY set
* Connected to 127.0.0.1 (127.0.0.1) port 32400 (#0)
* ALPN, offering h2
* ALPN, offering http/1.1
* Cipher selection: ALL:!EXPORT:!EXPORT40:!EXPORT56:!aNULL:!LOW:!RC4:@STRENGTH
* successfully set certificate verify locations:
* CAfile: /etc/ssl/certs/ca-certificates.crt
CApath: /etc/ssl/certs
* TLSv1.2 (OUT), TLS header, Certificate Status (22):
* TLSv1.2 (OUT), TLS handshake, Client hello (1):
* Unknown SSL protocol error in connection to 127.0.0.1:32400
* Curl_http_done: called premature == 1
* stopped the pause stream!
* Closing connection 0
curl: (35) Unknown SSL protocol error in connection to 127.0.0.1:32400
From Plex Media Server.log on omv (192.168.1.121 – UUID and username removed for privacy):
Oct 01, 2020 09:37:32.914 [0x7f273356f700] DEBUG - PublicAddressManager: Obtaining public address and mapping port.
Oct 01, 2020 09:37:32.944 [0x7f26e6ffd700] DEBUG - HTTP 200 response from PUT https://plex.tv/devices/mydeviceid?Connection[][uri]=http://192.168.1.121:32400&httpsEnabled=0&httpsRequired=0&dnsRebindingProtection=0&X-Plex-Token=xxxxxxxxxxxxxxxxxxxx
Oct 01, 2020 09:37:32.945 [0x7f26e6ffd700] DEBUG - CERT: Certificate or intermediate did not exist, fetching a new one.
Oct 01, 2020 09:37:32.945 [0x7f26e6ffd700] DEBUG - HTTP requesting POST https://plex.tv/devices/mydeviceid/certificate?version=2&X-Plex-Token=xxxxxxxxxxxxxxxxxxxx
Oct 01, 2020 09:37:33.005 [0x7f26967fc700] DEBUG - HTTP 422 response from POST https://plex.tv/servers.xml?auth_token=xxxxxxxxxxxxxxxxxxxx
Oct 01, 2020 09:37:33.006 [0x7f26967fc700] DEBUG - MyPlex: Published Mapping State response was 422
Oct 01, 2020 09:37:33.006 [0x7f26967fc700] DEBUG - MyPlex: Got response for mydeviceid ~ registered :0
Oct 01, 2020 09:37:33.006 [0x7f26967fc700] DEBUG - MyPlex: updating mapped state - current state: ‘Not Mapped’
Oct 01, 2020 09:37:33.006 [0x7f26967fc700] DEBUG - MyPlex: mapping state set to ‘Not Mapped’.
Oct 01, 2020 09:37:33.006 [0x7f273356f700] DEBUG - MyPlex: async reachability check - current mapped state: ‘Not Mapped’.
Oct 01, 2020 09:37:33.006 [0x7f273356f700] WARN - MyPlex: attempted a reachability check but we’re not yet mapped.
Oct 01, 2020 09:37:33.006 [0x7f273356f700] DEBUG - EventSource: Successfully connected to 184.105.148.114.
Oct 01, 2020 09:37:33.009 [0x7f2733d70700] DEBUG - Auth: authenticated user 1 as myuserid
Also the Cache directory on proli2 (for which secure works) contains ca.crt and certificate.p12. omv’s Cache directory does not. I tried to copy those two files from proli2 and they were removed.
Any ideas why it stopped working and how I can fix it? OMV is my main server. This was working until yesterday I had the brilliant idea to change my password and request a disconnection of all connected devices. This made me have to reattach my servers, and that’s when it happened.
