Good morning/afternoon/evening all!
I am new to the forums here, but have been using Plex since around 2012. (…and have been a proud plexpass “lifetime” subscriber since around 2014…it has really been worth every penny!
) Between using the documentation provided on this site, google searches, and just experimenting…any issues have been easily resolved.
But, there are two small questions on my mind - one I thought of recently, and the other has been in the back of my mind since the day I first set up the server.
The longtime question (mainly about TV Episodes):
The first time I set up Plex, I had (and even to this day have) all my media structured in the way that was recommended for the metadata to be downloaded and applied correctly.
e.g. "Drive Letter:/TV Shows/Show Name/Season X/Show Name - SXXEXX.ext"
When I first added TV Episodes, I added the folders of each show name:
e.g. "Drive Letter:/TV Shows/Show Name"
When I did this, Plex recognized, downloaded, and applied the correct metadata, but did not combine the seasons of any one show. I was left with various "Season X"s across the dashboard under TV Shows.
I had found a workaround by adding each season separately, and for years, have been adding TV shows (as I rip and record them) to Plex one season at a time.
e.g. "Drive Letter:/TV Shows/Show Name/Season X"
Everything has been working well using this method, but can be tedious at times when you’re adding a box set.
So my first question is - Is there a correct and easier way to add TV Shows. At which folder do you “tell” Plex to look at?
The second, and most recent, question came about when I started playing around with H.265 encoding. I’ve heard before that H.265 makes the processor “hurt” during transcoding. A day or two ago, I was “prepping” up a tv episode (cutting commercials and encoding), and decided to see how well Plex transcoded H.265. I was really impressed when I streamed the episode to my tv, and it used really little processing power (I had the task manager up on the server). To save space, I would like to start encoding media using H.265. Does Plex support H.265 “all around”? (whether it’s animation, a full length movie, etc)…or should I keep with H.264 for the time being?
Thanks in advance for any and all help!
