Unable to claim server
Hi! Have you heard any further updates in regards to claiming new servers?
@e1plex4
I have reset your certificate. It looked ok but I reset it anyway.
Please restart the server.
After the server is restarted, Restart all devices which connect to it so they may also get the new certificate.
@wutru09
In your logs, I do not see the normal PMS startup where it loads the certificate.
This is concerning.
Please go into /config/Library/Application Support/Plex Media Server/Cache
and remove cert-v2.p12 .
Next restart the server.
Allow a minute or so for Plex.tv to generate a new certificate
Next, restart the apps (plex/web, etc) so they update with the new certificate.
Hi Chuck,
This is the account / server that is having issues
 e1iteplex6, Can please we try resetting this certificate to see if i can be able to claim my server again? Thank you
How to we do this,
This is concerning.
My problem still persists. I just set up a new server on my Windows desktop and have the same problem.
@ElitePlex6
Your server certificate looked ok.
I reset it anyway.
You should SSH tunnel to the machine, restart the server, and reclaim it.
@wutru09
I had chance to look deeper into your logs.
Your container LAN addresses are constantly resetting _---- NOT GOOD.
Looks like the DHCP server is firing too fast.
Sep 15, 2023 17:28:11.891 [139985163610936] DEBUG - Request: [127.0.0.1:47074 (Loopback)] GET /:/plugins/com.plexapp.agents.thetvdb (2 live) #48 GZIP Token ()
Sep 15, 2023 17:28:11.891 [139985163610936] WARN - [Req#48] Request for plug-in [com.plexapp.agents.thetvdb] but it doesn't exist.
Sep 15, 2023 17:28:11.891 [139985220680504] DEBUG - Completed: [127.0.0.1:47074] 404 GET /:/plugins/com.plexapp.agents.thetvdb (2 live) #48 GZIP 0ms 350 bytes
Sep 15, 2023 17:28:11.951 [139985203231544] DEBUG - [HttpClient/HCl#10] HTTP/1.1 (0.2s) 200 response from GET http://127.0.0.1:41973/system/agents
Sep 15, 2023 17:28:11.951 [139985208216376] DEBUG - [com.plexapp.system] HTTP reply status 200, with 249 bytes of content.
Sep 15, 2023 17:28:11.952 [139985208216376] DEBUG - The system knows about 1 agents.
Sep 15, 2023 17:28:12.061 [139985190193976] DEBUG - NetworkInterface: received Netlink message len=1352, type=RTM_NEWLINK, flags=0x0
Sep 15, 2023 17:28:12.061 [139985190193976] DEBUG - NetworkInterface: Netlink information message family=0, type=65534, index=882, flags=0x1090, change=0xffffffff
Sep 15, 2023 17:28:12.061 [139985190193976] DEBUG - Network change.
Sep 15, 2023 17:28:12.061 [139985190193976] DEBUG - NetworkInterface: Notified of network changed (force=0)
Sep 15, 2023 17:28:12.101 [139985190193976] DEBUG - Network change notification but nothing changed.
Sep 15, 2023 17:28:12.101 [139985190193976] DEBUG - NetworkInterface: received Netlink message len=1352, type=RTM_NEWLINK, flags=0x0
Sep 15, 2023 17:28:12.101 [139985190193976] DEBUG - NetworkInterface: Netlink information message family=0, type=65534, index=882, flags=0x1090, change=0x0
Sep 15, 2023 17:28:12.101 [139985190193976] DEBUG - Network change.
Sep 15, 2023 17:28:12.101 [139985190193976] DEBUG - NetworkInterface: Notified of network changed (force=0)
Sep 15, 2023 17:28:12.112 [139985190193976] DEBUG - Network change notification but nothing changed.
Sep 15, 2023 17:28:12.112 [139985190193976] DEBUG - NetworkInterface: received Netlink message len=1356, type=RTM_NEWLINK, flags=0x0
Sep 15, 2023 17:28:12.112 [139985190193976] DEBUG - NetworkInterface: Netlink information message family=0, type=65534, index=882, flags=0x110d1, change=0x1
Sep 15, 2023 17:28:12.112 [139985190193976] DEBUG - Network change.
Sep 15, 2023 17:28:12.112 [139985190193976] DEBUG - NetworkInterface: Notified of network changed (force=0)
Sep 15, 2023 17:28:12.113 [139985190193976] DEBUG - Network change notification but nothing changed.
Sep 15, 2023 17:28:12.113 [139985190193976] DEBUG - NetworkInterface: received Netlink message len=88, type=RTM_DELADDR, flags=0x0
Sep 15, 2023 17:28:12.113 [139985190193976] DEBUG - NetworkInterface: Netlink address message family=2, index=882, flags=0x80
Sep 15, 2023 17:28:12.113 [139985190193976] DEBUG - Network change.
Sep 15, 2023 17:28:12.113 [139985190193976] DEBUG - NetworkInterface: Notified of network changed (force=0)
Sep 15, 2023 17:28:12.114 [139985190193976] DEBUG - Network change notification but nothing changed.
Sep 15, 2023 17:28:12.114 [139985190193976] DEBUG - NetworkInterface: received Netlink message len=88, type=RTM_GETADDR, flags=0x0
Sep 15, 2023 17:28:12.114 [139985190193976] DEBUG - NetworkInterface: Netlink address message family=2, index=882, flags=0x80
Sep 15, 2023 17:28:12.114 [139985190193976] DEBUG - Network change.
Sep 15, 2023 17:28:12.114 [139985190193976] DEBUG - NetworkInterface: Notified of network changed (force=0)
Sep 15, 2023 17:28:12.115 [139985190193976] DEBUG - Network change notification but nothing changed.
Sep 15, 2023 17:28:12.120 [139985190193976] DEBUG - NetworkInterface: received Netlink message len=1356, type=RTM_NEWLINK, flags=0x0
Sep 15, 2023 17:28:12.120 [139985190193976] DEBUG - NetworkInterface: Netlink information message family=0, type=65534, index=882, flags=0x1090, change=0x41
Sep 15, 2023 17:28:12.120 [139985190193976] DEBUG - Network change.
Sep 15, 2023 17:28:12.120 [139985190193976] DEBUG - NetworkInterface: Notified of network changed (force=0)
Sep 15, 2023 17:28:12.121 [139985190193976] DEBUG - Network change notification but nothing changed.
Sep 15, 2023 17:28:12.121 [139985190193976] DEBUG - NetworkInterface: received Netlink message len=596, type=RTM_DELLINK, flags=0x0
Sep 15, 2023 17:28:12.121 [139985190193976] DEBUG - NetworkInterface: Netlink information message family=0, type=65534, index=882, flags=0x1090, change=0xffffffff
Sep 15, 2023 17:28:12.184 [139985168235320] DEBUG - Request: [127.0.0.1:47086 (Loopback)] GET /:/plugins/com.plexapp.system/messaging/function/X0FnZW50U2VydmljZTpVcGRhdGVJbmZv/Y2VyZWFsMQoxCmxpc3QKMApyMAo_/Y2VyZWFsMQo1CmRpY3QKbGlzdApkaWN0Cmxpc3QKbGlzdAoyCnMyNQpjb20ucGxleGFwcC5hZ2VudHMubGFzdGZtczEwCmlkZW50aWZpZXJyMQpzMTAKYWdlbnRfaW5mbzEK
Unfortunately, still unable to claim a server. bought a Plex pass on another account and still the same :frowning:
Hi @ChuckPa
Thanks for the response!
I tried your first sollution but after a few restarts and waits no cert-v2.p12 certificate was generated. Then I installed plex on my home laptop (Windows), and it worked immediately.
After your post of the network card errors I just reĂŻnstalled the whole system (to double check), installed plex again and now everything is working ok.
Thanks for your time :slight_smile:
@wutru09
You’re rapid cycling through new hosts & certificates at an alarming rate.
Slow down please.
If you do too many too quickly, plex.tv will throttle you and deny claiming new hosts.
May I see your Logs please which show the claiming attempts ?
@ChuckPa
Well I got some other problems using plex (after a server restart I get “non secure connection” which I can’t get rid of except reïnstalling), but I think this doesn’t belong in this topic anymore.
I don’t have the claim problem anymore, so thanks :slight_smile:
Hi I found this thread after making my thread Fresh Docker install and unable to claim server this thread seems to have the most plex employees helping
I’m self hosting as well and unable to claim my server after I started fresh from a new container and volume. Is there a specific log you need within the zip files?
If you want to create a new thread and ping me ( @chuckpa ), please do.
We’ll fix whatever is left to fix
