Problem claiming this server
I’ve had Plex installed for several years on my Ubuntu system. For some reason recently it started giving me the “No soup for you” message from the local system. I could still manage it from a different machine but the local system seemed to be hosed. Nothing I tried, including editing the Preferences.xml as noted in other posts, worked.
Finally, I uninstalled Plex and renamed the /var/lib/plexmediaserver folder to plexmediaservr.bak. I then reinstalled the latest version with dpkg -i .
Now, when I go to localhost:32400/web and try to setup the server I get the dreaded “Problem claiming this server” message. Nothing I do can make this go away or allow me to get Plex working again.
I’m fine setting it up again, it’s not that difficult but how does one get past this error message?
The entries in Plex Media Server.log are below.
Mar 22, 2021 11:45:04.207 [0x7f4a926ca700] DEBUG - Request: [127.0.0.1:44604 (Loopback)] PUT /:/prefs?PublishServerOnPlexOnlineKey=1 (5 live) GZIP Token ()
Mar 22, 2021 11:45:04.208 [0x7f4a926ca700] DEBUG - MyPlex: Toggling server publish state.
Mar 22, 2021 11:45:04.208 [0x7f4a926ca700] DEBUG - MyPlex: start public ip check and mapping - current mapped state: ‘Mapped - Not Published (Bad Authentication)’.
Mar 22, 2021 11:45:04.208 [0x7f4a91ec9700] DEBUG - Completed: [127.0.0.1:44604] 200 PUT /:/prefs?PublishServerOnPlexOnlineKey=1 (5 live) GZIP 0ms 323 bytes (pipelined: 2)
Mar 22, 2021 11:45:04.961 [0x7f4a926ca700] DEBUG - Request: [127.0.0.1:44604 (Loopback)] POST /myplex/claim?token=xxxxxxxxxxxxxxxxxxxx5YLF9a (5 live) GZIP Token ()
Mar 22, 2021 11:45:04.962 [0x7f4a926ca700] DEBUG - HTTP requesting POST https://plex.tv/api/claim/exchange?token=xxxxxxxxxxxxxxxxxxxx5YLF9a
Mar 22, 2021 11:45:05.300 [0x7f4a926ca700] ERROR - Error issuing curl_easy_perform(handle): 60
Mar 22, 2021 11:45:05.300 [0x7f4a926ca700] WARN - HTTP error requesting POST https://plex.tv/api/claim/exchange?token=xxxxxxxxxxxxxxxxxxxx5YLF9a (60, SSL peer certificate or SSH remote key was not OK) (SSL certificate problem: unable to get local issuer certificate)
Mar 22, 2021 11:45:05.300 [0x7f4a926ca700] DEBUG - MyPlex: Did token exchange for claim (returnCode: -60)
Mar 22, 2021 11:45:05.300 [0x7f4a926ca700] DEBUG - Need to restart some processes because of a change to the security environment.
Mar 22, 2021 11:45:05.300 [0x7f4a926ca700] DEBUG - MyPlex: Got a token poked, let’s act on it.
Mar 22, 2021 11:45:05.300 [0x7f4a80ddf700] DEBUG - PluginRepository::setStartState: 0, initializing
Mar 22, 2021 11:45:05.300 [0x7f4a80ddf700] DEBUG - Stopping [com.plexapp.system].
Mar 22, 2021 11:45:05.300 [0x7f4a80ddf700] DEBUG - [com.plexapp.system] Killing.
Mar 22, 2021 11:45:05.301 [0x7f4a80ddf700] DEBUG - PluginRepository::setStartState: 1, startingSystem
Mar 22, 2021 11:45:05.301 [0x7f4a80ddf700] DEBUG - Starting file watcher for com.plexapp.system
Mar 22, 2021 11:45:05.301 [0x7f4a80ddf700] DEBUG - Plugin: not setting user token for plugin
Mar 22, 2021 11:45:05.301 [0x7f4a926ca700] DEBUG - HTTP requesting GET https://plex.tv/api/v2/user/privacy?X-Plex-Token=
Mar 22, 2021 11:45:05.301 [0x7f4a80ddf700] DEBUG - Spawned plug-in com.plexapp.system with PID 16380
Mar 22, 2021 11:45:05.301 [0x7f4a80ddf700] DEBUG - [com.plexapp.system] Sending command: GET /:/prefixes
Mar 22, 2021 11:45:05.303 [0x7f4a92ecb700] WARN - JobManager: Could not find job for handle 16314
Mar 22, 2021 11:45:05.669 [0x7f4a926ca700] ERROR - Error issuing curl_easy_perform(handle): 60
Mar 22, 2021 11:45:05.669 [0x7f4a926ca700] WARN - HTTP error requesting GET https://plex.tv/api/v2/user/privacy?X-Plex-Token=xxxxxxxxxxxxxxxxxxxxficate or SSH remote key was not OK) (SSL certificate problem: unable to get local issuer certificate)
Mar 22, 2021 11:45:05.670 [0x7f4a926ca700] WARN - [Analytics] Couldn’t get analytics privacy settings. Trying again soon.
Mar 22, 2021 11:45:05.670 [0x7f4a926ca700] DEBUG - HTTP requesting GET https://plex.tv/api/v2/release_channels?X-Plex-Token=
Mar 22, 2021 11:45:06.008 [0x7f4a926ca700] ERROR - Error issuing curl_easy_perform(handle): 60
Mar 22, 2021 11:45:06.008 [0x7f4a926ca700] WARN - HTTP error requesting GET https://plex.tv/api/v2/release_channels?X-Plex-Token=xxxxxxxxxxxxxxxxxxxxficate or SSH remote key was not OK) (SSL certificate problem: unable to get local issuer certificate)
Mar 22, 2021 11:45:06.008 [0x7f4a926ca700] WARN - [AutoUpdateRequestHandler] Couldn’t get update channels. Trying again soon.
Mar 22, 2021 11:45:06.008 [0x7f4a926ca700] DEBUG - Sync: onMyPlexSignOut
Mar 22, 2021 11:45:06.009 [0x7f4a926ca700] DEBUG - HTTP requesting GET https://plex.tv/api/v2/features?X-Plex-Token=
Mar 22, 2021 11:45:06.348 [0x7f4a926ca700] ERROR - Error issuing curl_easy_perform(handle): 60
Mar 22, 2021 11:45:06.348 [0x7f4a926ca700] WARN - HTTP error requesting GET https://plex.tv/api/v2/features?X-Plex-Token=xxxxxxxxxxxxxxxxxxxxficate or SSH remote key was not OK) (SSL certificate problem: unable to get local issuer certificate)
Mar 22, 2021 11:45:06.349 [0x7f4a926ca700] WARN - FeatureManager: Couldn’t get features. Trying again soon.
Mar 22, 2021 11:45:06.349 [0x7f4a916c8700] DEBUG - Completed: [127.0.0.1:44604] 500 POST /myplex/claim?token=xxxxxxxxxxxxxxxxxxxx5YLF9a (7 live) GZIP 1387ms 533 bytes (pipelined: 3)
Mar 22, 2021 11:45:06.349 [0x7f4a926ca700] DEBUG - Request: [127.0.0.1:44638 (Loopback)] GET /:/plugins/com.plexapp.system/messaging/function/X0J1bmRsZVNlcnZpY2U6QWxsU2VydmljZXM_/Y2VyZWFsMQoxCmxpc3QKMApyMAo_/Y2VyZWFsMQoxCmRpY3QKMApyMAo_ (7 live) GZIP
Mar 22, 2021 11:45:06.349 [0x7f4a6a7fc700] DEBUG - Request: [127.0.0.1:44640 (Loopback)] GET / (7 live) GZIP
Mar 22, 2021 11:45:06.349 [0x7f4a91ec9700] DEBUG - Completed: [127.0.0.1:44640] 200 GET / (7 live) GZIP 0ms 1208 bytes
Mar 22, 2021 11:45:06.377 [0x7f4a6a7fc700] DEBUG - Request: [[::1]:60760 (Loopback)] GET /web/favicon.ico (6 live) GZIP
Mar 22, 2021 11:45:06.377 [0x7f4a6a7fc700] DEBUG - Final path: “/usr/lib/plexmediaserver/Resources/Plug-ins-c073686f2/WebClient.bundle/Contents/Resources/favicon.ico”
Mar 22, 2021 11:45:06.377 [0x7f4a6a7fc700] DEBUG - Content-Length of /usr/lib/plexmediaserver/Resources/Plug-ins-c073686f2/WebClient.bundle/Contents/Resources/favicon.ico is 5430 (of total: 5430).
Mar 22, 2021 11:45:06.377 [0x7f4a916c8700] DEBUG - Completed: [[::1]:60760] 200 GET /web/favicon.ico (6 live) GZIP 0ms 5430 bytes (pipelined: 2)
Mar 22, 2021 11:45:06.411 [0x7f4a01ffb700] ERROR - Error issuing curl_easy_perform(handle): 60
Mar 22, 2021 11:45:06.737 [0x7f4a6a7fc700] DEBUG - Request: [127.0.0.1:44648 (Loopback)] GET /servers (7 live) GZIP
Mar 22, 2021 11:45:06.737 [0x7f4a916c8700] DEBUG - Completed: [127.0.0.1:44648] 200 GET /servers (7 live) GZIP 0ms 493 bytes
Mar 22, 2021 11:45:06.743 [0x7f4a6a7fc700] DEBUG - Request: [127.0.0.1:44650 (Loopback)] GET /library/sections (7 live) GZIP
Mar 22, 2021 11:45:06.743 [0x7f4a916c8700] DEBUG - Completed: [127.0.0.1:44650] 200 GET /library/sections (7 live) GZIP 0ms 474 bytes
Mar 22, 2021 11:45:06.748 [0x7f4a6a7fc700] DEBUG - Request: [127.0.0.1:44652 (Loopback)] GET /channels/all (7 live) GZIP
Mar 22, 2021 11:45:06.748 [0x7f4a916c8700] DEBUG - Completed: [127.0.0.1:44652] 200 GET /channels/all (7 live) GZIP 0ms 387 bytes
Mar 22, 2021 11:45:06.749 [0x7f4a80ddf700] DEBUG - Reading 486 bytes in the body, code is 200
Mar 22, 2021 11:45:06.749 [0x7f4a80ddf700] DEBUG - [com.plexapp.system] Plug-in running on port 44683.
Mar 22, 2021 11:45:06.749 [0x7f4a80ddf700] DEBUG - * Plug-in handles prefix: /system
Mar 22, 2021 11:45:06.749 [0x7f4a80ddf700] DEBUG - * Plug-in handles prefix: /player
Mar 22, 2021 11:45:06.749 [0x7f4a80ddf700] DEBUG - Read configuration for [com.plexapp.system], had 2 prefixes
Mar 22, 2021 11:45:06.749 [0x7f4a80ddf700] DEBUG - System bundle was restarted, we need to notify other plug-ins
Mar 22, 2021 11:45:06.749 [0x7f4a80ddf700] DEBUG - PluginRepository::setStartState: 3, complete
Mar 22, 2021 11:45:06.749 [0x7f4a926ca700] DEBUG - [com.plexapp.system] Sending command over HTTP (GET): /:/plugins/com.plexapp.system/messaging/function/X0J1bmRsZVNlcnZpY2U6QWxsU2VydmljZXM_/Y2VyZWFsMQoxCmxpc3QKMApyMAo_/Y2VyZWFsMQoxCmRpY3QKMApyMAo_
Mar 22, 2021 11:45:06.749 [0x7f4a926ca700] DEBUG - HTTP requesting GET http://127.0.0.1:44683/:/plugins/com.plexapp.system/messaging/function/X0J1bmRsZVNlcnZpY2U6QWxsU2VydmljZXM_/Y2VyZWFsMQoxCmxpc3QKMApyMAo_/Y2VyZWFsMQoxCmRpY3QKMApyMAo_
Mar 22, 2021 11:45:06.777 [0x7f4a926ca700] DEBUG - HTTP 200 response from GET http://127.0.0.1:44683/:/plugins/com.plexapp.system/messaging/function/X0J1bmRsZVNlcnZpY2U6QWxsU2VydmljZXM_/Y2VyZWFsMQoxCmxpc3QKMApyMAo_/Y2VyZWFsMQoxCmRpY3QKMApyMAo_
Mar 22, 2021 11:45:06.777 [0x7f4a926ca700] DEBUG - [com.plexapp.system] HTTP reply status 200, with 516 bytes of content.
Mar 22, 2021 11:45:06.777 [0x7f4a916c8700] DEBUG - Completed: [127.0.0.1:44638] 200 GET /:/plugins/com.plexapp.system/messaging/function/X0J1bmRsZVNlcnZpY2U6QWxsU2VydmljZXM_/Y2VyZWFsMQoxCmxpc3QKMApyMAo_/Y2VyZWFsMQoxCmRpY3QKMApyMAo_ (6 live) GZIP 428ms 633 bytes
Mar 22, 2021 11:45:07.319 [0x7f4a916c8700] DEBUG - Completed: [127.0.0.1:44414] 200 GET /player/proxy/poll?deviceClass=pc&protocolVersion=3&protocolCapabilities=timeline%2Cplayback%2Cnavigation%2Cmirror%2Cplayqueues&timeout=1 (5 live) GZIP 20000ms 5 bytes (pipelined: 15)
Mar 22, 2021 11:45:07.327 [0x7f4a6a7fc700] DEBUG - Request: [127.0.0.1:44414 (Loopback)] GET /player/proxy/poll?deviceClass=pc&protocolVersion=3&protocolCapabilities=timeline%2Cplayback%2Cnavigation%2Cmirror%2Cplayqueues&timeout=1 (5 live) GZIP Token ()
Mar 22, 2021 11:45:07.327 [0x7f4a6a7fc700] DEBUG - Content-Length is -1 (of total: -1).
I’ve had a same-ish problem. Might want to try this and claim the server within 5 minutes.
Thanks for the quick reply. Just after I submitted I figured it out. I was doing some SSL decryption and not using a trusted key. The errors in the log are related to the SSL certificate. My bad…
