Unable to connect - again!
Server Version#:1.21.2.3943-a91458577
Player Version#:2.012
Once again my samsung tv app can not connect to to my server running on my pc
This happens way too often and it seems always when there is an update and I haven’t used plex for awhile
please help
Thanks as always in advance
UPDATE:
After searching for a few hours I found a solution that seems to work. For anyone else having this issue with an older Samsung this is what worked for me:
  1. on your PC, go to your plex via web browser, then go to settings and remove the Samsung TV as an authorized device.
  2. On the Samsung TV, if you can go to the plex app and then settings > advanced > reset app. This did not work for me so I had to go on the Samsung TV, DELETE the Plex App then re-download it
  3. You should now get the prompt to go to the plex.tv/link url and re-add the TV as an Authorized Device
That’s what worked for my anyway - best of luck
