Unable to Connect to Shield PMS Securely
Downloaded Hot Fix #3- haven’t been able to get my Plex server working since this mess started. I factory reset my shield and I’m willing to start fresh with a new database/server but the obstacle I’m running into now is that it can’t connect securely.
The support article in secure connections isn’t as straightforward as others and I think I’m set up properly but what should I be checking in the Plex app settings or Shield settings?
Server Version#: v1.25.3.5448
For initial claiming and setup, connect directly to the server: http://shield_ip_goes_here:32400/web
