Unable to connect to updated Plex install on a DS216+
Server Version#:DSM 6.2-23739 Update 2
Player Version#:1.13.8.5395-10d48da0d
NAS Model DS216+
recently updated the Plex install on my NAS. Now i can’t seem to connect to it.
Even internally on my network using my nas IP address i can login to Plex in general but it will say my server is unavalable/unreachable or will not list it at all. (I have Plex on a windows pc as well that connects and shows on my list.)
in DSM the app/service is running but no worky.
Attached logs.SynoPlex-Logs.zip (4.9 MB)
remove the current version.
re-install the previous.
your library is safe during this operation.
Also stop the docker containers from running until you have control again.
ok, where do i download the previous version. the webpage keeps offering me the one i have now.
Thx
I found an install for PlexMediaServer-1.13.5.5332-21ab172de-x86_64.spk.
i have removed and reinstalled this version and seems to be working now.
Thanks.
Nope. it’s missing again. Says unavailable on the plex page
removed from server list to repopulated once i restart it, and it hasn’t come back.
:frowning:
Ok, let’s do this MY way (I will beat it into submission haha)
  1. Open the Plex share in FileStation
  2. Navigate Plex / Library / Application Support / Plex Media Server
  3. Right-click Logs
  4. Compress to Logs.zip
  5. Attach the ZIP file it presents you.
  6. I will find out what it’s whining about and help you slap it silly :smiley:
ok, i had attached the logs from my first post. i can send an update if that’s what you need.
attachedPlexLogs20180927.zip (4.2 MB)
Thanks.
You’re experiencing major network errors.
From DNS lookup failures to complete timeouts.
Sep 27, 2018 11:40:05.891 [0x7f01053ff700] DEBUG - Auth: authenticated user 1 as david_w_neumann
Sep 27, 2018 11:40:05.892 [0x7f010277d700] DEBUG - Request: [192.168.0.211:58087 (Subnet)] GET /player/proxy/poll?deviceClass=pc&protocolVersion=1&protocolCapabilities=timeline%2Cplayback%2Cnavigation%2Cmirror%2Cplayqueues&timeout=1 (11 live) TLS GZIP Signed-in Token (david_w_neumann)
Sep 27, 2018 11:40:05.893 [0x7f010277d700] DEBUG - Beginning read from two-way stream.
Sep 27, 2018 11:40:08.416 [0x7f01053ff700] DEBUG - EventSource: Failure in IdleTimeout (0 - Success).
Sep 27, 2018 11:40:13.415 [0x7f01053ff700] WARN - PubSubManager: Connection to 50.116.44.223 failed: Connection timed out.
Sep 27, 2018 11:40:13.415 [0x7f01053ff700] ERROR - EventSource: Retrying in 240 seconds.
Sep 27, 2018 11:40:25.893 [0x7f0105111700] DEBUG - handleStreamRead code 335544539: short read
Sep 27, 2018 11:40:25.900 [0x7f01053ff700] DEBUG - Auth: authenticated user 1 as david_w_neumann
Sep 27, 2018 11:40:25.901 [0x7f010277d700] DEBUG - Request: [192.168.0.211:58146 (Subnet)] GET /player/proxy/poll?deviceClass=pc&protocolVersion=1&protocolCapabilities=timeline%2Cplayback%2Cnavigation%2Cmirror%2Cplayqueues&timeout=1 (10 live) TLS GZIP Signed-in Token (david_w_neumann)
Sep 27, 2018 11:40:25.902 [0x7f010277d700] DEBUG - Beginning read from two-way stream.
Sep 27, 2018 11:40:33.605 [0x7f01053ff700] DEBUG - Auth: authenticated user 1 as david_w_neumann
Sep 27, 2018 11:40:33.606 [0x7f01043ff700] DEBUG - Request: [192.168.0.51:57790 (Subnet)] PUT /myplex/refreshReachability (11 live) Signed-in Token (david_w_neumann)
Sep 27, 2018 11:40:34.201 [0x7f00fedad700] ERROR - Error issuing curl_easy_perform(handle): 6
Sep 27, 2018 11:40:34.201 [0x7f00fedad700] WARN - HTTP error requesting PUT https://plex.tv/api/servers/9a06d776a58219c4d162b784b71a043faa31b1f3/connectivity?X-Plex-Token=xxxxxxxxxxxxxxxxxxxx&asyncIdentifier=61497c1f-bdb8-45a6-b52c-ad43da33ca6a (0, No error) (Couldn't resolve host 'plex.tv')
Sep 27, 2018 11:40:34.202 [0x7f00fbbff700] DEBUG - MyPlex: Requesting reachability check.
Sep 27, 2018 11:40:34.202 [0x7f0105111700] DEBUG - Completed: [192.168.0.51:57592] 200 PUT /myplex/refreshReachability (11 live) 195533ms 195 bytes (pipelined: 1)
Sep 27, 2018 11:40:34.205 [0x7f00fbbff700] DEBUG - HTTP requesting PUT https://plex.tv/api/servers/9a06d776a58219c4d162b784b71a043faa31b1f3/connectivity?X-Plex-Token=xxxxxxxxxxxxxxxxxxxx&asyncIdentifier=16d0b7a1-bc35-4a6d-b003-6682855404f8
Sep 27, 2018 11:40:40.123 [0x7f00fe5ce700] ERROR - Error issuing curl_easy_perform(handle): 6
ok, checked my DNS entries on my router and rebooted it and we are good now.
Thanks.
